Thread: Tilting motor forward
Results 1 to 13 of 13
  1. #1 Re: Tilting motor forward
    PA
    Quote Originally Posted by GP_Kid18 View Post
    dose the E-brake hold the motor in place?
    also my brothers friends are mechanics and they told me that there is a tool the you put in place of the dog bones and you crank it one way to pull the motor to the front and crank it the other way to push it back
    With all four wheels on the ground, you unhook the dogbones. This allows the engine to move some. Then push the car a little. The force from the front wheels will push the engine back and forth. Just push the car until the engine tilts forward. Then set the e-brake so the car will stay in the exact same spot. As long as all four wheels are on the ground with the e-brake set, the engine will stay in the same spot.
    2001 GSE
  2. #2 Re: Tilting motor forward
    GT Level Member DesQ27's Avatar
    May 2008
    Kennewick
    Why is it a good idea to tilt the motor??
    "True measure of a man's strength is his self control in time of great stress" - ME
    2002 GTP: U-Bend and Resonator Delete; Mufflers Modded; K&N Short Ram Air; WS6 Ram Air Hood
  3. #3 Re: Tilting motor forward
    Dec 2008
    Canada
    Quote Originally Posted by DesQ27 View Post
    The only reason I can think of is to make it easier to reach stuff, other than that I've racked my brain trying to figure out what it could be.
  4. #4 Re: Tilting motor forward
    it makes it about 50x easier to get to anything on the rear of the motor if it is tilted forward farther.
    it helps a ton if you have a ratcheting strap and youre doing headers.
  1. will a 03 gtp motor work in a 98 gtp????
    By gtpmadman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2008, 11:05 AM
  2. Motor mount help for 94 GP
    By 954mula in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-07-2008, 12:02 AM
  3. Tilting 9007's!
    By Toasty in forum Visual/Body Modifications
    Last Post: 03-25-2008, 07:59 AM
  4. Motor Trend First Look '09 ZR-1...
    By newfie in forum Off Topic Discussion
    Last Post: 01-23-2008, 07:58 AM
  5. Pics of motor
    By RED GTX in forum Turbo
    Last Post: 01-22-2008, 08:26 PM
