Thread: More power!?!?!?!?!?!?!
Results 1 to 10 of 10
  1. #1 More power!?!?!?!?!?!?!
    SE Level Member GINOSGTP's Avatar
    Feb 2009
    Ontario Canada
    Hey ......i own a 2002 GTP i want to add a intercooler to my car but am worried that i dont have all the supporting mods to get the most power i can.
    Mods so far:
    Downpipe
    cat back
    3.4 pulley
    8.8mm wires
    FWI
    ported gen III
    ported exhaust manifolds
    zz pcm
    I just baught a stage 3 intercooler with ported llower intake....i know my car needs a tune and was wondering if any other mods need to be done to get the most out of the set up im going to run.....keep in mind head work is next year so no rockers etc....
    any help would be more than beneficial
  2. #2 Re: More power!?!?!?!?!?!?!
    TDCRacing
    Guest
    SCAN GUAGE
    Tuner
    Headers
  3. #3 Re: More power!?!?!?!?!?!?!
    an intercooler is nearly a bolt on and run part. you should be able to lean the car out a little more with it.
    if you plan on going much further with the car, invest in a wideband now.
  4. #4 Re: More power!?!?!?!?!?!?!
    Feb 2009
    Ontario Canada
    so if i understand what your sayen.......i get a good tune and bolt my intercooler ....i should be fine? would a MAF sensor help?
  5. #5 Re: More power!?!?!?!?!?!?!
    TDCRacing
    Guest
    Quote Originally Posted by GINOSGTP View Post
    You would only need an aftermarket MAF sensor if you would drop to a lower pully. And you would need this because you would be going over the maximum airflow range allowed by the stock one. Then you would need to switch to a LQ4 MAF setup.
    You would also need a new MAF table if you would do so. So tuning is required.
  6. #6 Re: More power!?!?!?!?!?!?!
    Feb 2009
    Ontario Canada
    so if i wanted to run a 3.25" or lower size in pulley i would need a MAF?
  7. #7 Re: More power!?!?!?!?!?!?!
    TDCRacing
    Guest
    More than likley. Maybe even with a 3.3
  8. #8 Re: More power!?!?!?!?!?!?!
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    No. It is just fine with my 3.1" pulley.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  9. #9 Re: More power!?!?!?!?!?!?!
    TDCRacing
    Guest
    Good advice. And I will recomend the NGK AFX wideband.
  10. #10 Re: More power!?!?!?!?!?!?!
    Moore, Oklahoma
    Hell, my black car has less mods than you and runs an IC just fine...
    -Thrasher CAI w/ 9" K&N
    -DUB 3.25" Pulley
    -ILGPC Intercooler
    -Autolite 104s @ .054
    -JimmyC 3" Catless Downpipe
    -Overkill PCM
    Every thing else stock! Stock rockers, cam, manifolds, LIM, catback, block, trans, S/C, TB, etc etc.
    An intercooler (a full size, not an SS) is the single best mod for these cars. As far as i'm concerned, GM should of ICed these cars from the factory.
    At any stage, even bone stock, an intercooler will never be a bad mod. Although you won't see much benefits unless your getting a crapload of knock or you raise the boost. You'll always benefit with an IC without a doubt.
    Shawn W. Larsen
  1. Where did my power go??
    By Bandit1228 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2009, 09:53 PM
  2. Need more N.A power
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2008, 01:32 AM
  3. tcs off = more power ??
    Last Post: 08-29-2008, 01:44 AM
  4. Need more power help!!!
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-02-2008, 09:02 PM
  5. Power Cut off
    By bburrows in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 05:07 PM
