Thread: More power!?!?!?!?!?!?!
Results 1 to 10 of 10
  1. #1 Re: More power!?!?!?!?!?!?!
    an intercooler is nearly a bolt on and run part. you should be able to lean the car out a little more with it.
    if you plan on going much further with the car, invest in a wideband now.
  2. #2 Re: More power!?!?!?!?!?!?!
    SE Level Member GINOSGTP's Avatar
    Feb 2009
    Ontario Canada
    so if i understand what your sayen.......i get a good tune and bolt my intercooler ....i should be fine? would a MAF sensor help?
  3. #3 Re: More power!?!?!?!?!?!?!
    TDCRacing
    Guest
    Quote Originally Posted by GINOSGTP View Post
    You would only need an aftermarket MAF sensor if you would drop to a lower pully. And you would need this because you would be going over the maximum airflow range allowed by the stock one. Then you would need to switch to a LQ4 MAF setup.
    You would also need a new MAF table if you would do so. So tuning is required.
  4. #4 Re: More power!?!?!?!?!?!?!
    Feb 2009
    Ontario Canada
    so if i wanted to run a 3.25" or lower size in pulley i would need a MAF?
  5. #5 Re: More power!?!?!?!?!?!?!
    TDCRacing
    Guest
    More than likley. Maybe even with a 3.3
  6. #6 Re: More power!?!?!?!?!?!?!
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    No. It is just fine with my 3.1" pulley.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  7. #7 Re: More power!?!?!?!?!?!?!
    TDCRacing
    Guest
    Good advice. And I will recomend the NGK AFX wideband.
  1. Where did my power go??
    By Bandit1228 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2009, 09:53 PM
  2. Need more N.A power
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2008, 01:32 AM
  3. tcs off = more power ??
    Last Post: 08-29-2008, 01:44 AM
  4. Need more power help!!!
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-02-2008, 09:02 PM
  5. Power Cut off
    By bburrows in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 05:07 PM
