As the title states, I'm leaking power steering fluid and it's more than a drip. Problem is I can't tell where it's coming from. I cleaned off the whole area with brake fluid and nothing leaks when the engine is running. I even turned the wheel multiple times and no drips. However, in the morning when it's cold there will be a small puddle about the size of a donut under the car after about 10 minutes. Seems like once the fluid is warmed up wherever it's leaking from the seals expand and it stops. I guess I'm gonna have to go out there and freeze my a** off to find out what is going on. Any guesses on where it's leaking?
Another strange issue I'm having is my key fob wouldn't work in the morning so I thought the battery was going dead and replaced it. Next day, same thing. I keep the key on a hook in the garage and thought maybe the cold is affecting it? Sure enough, the next day after keeping the fob in the house overnight it worked the next morning. What could be going on there? None of my other fob's hanging out there have issues.
