Thread: Transmission leaking fluid from the top?
Results 1 to 2 of 2
  1. #1 Transmission leaking fluid from the top?
    SE Level Member awildryan's Avatar
    Oct 2012
    Kent, Ohio
    Hi, I have a 2001 grand prix gt with the 3800. It worked fine until recently it was leaking transmission fluid, when I went to check the lines I noticed that it was not leaking from the lines, but rather from what I assume is the breather on top. After that I gave it a new filter and fresh trans fluid, but it still did it. After that I checked to see if the radiator cooler was clogged, but the cooler flows both ways and both lines flow.
    I don't have any other ideas, if anyone has an idea or, knows what the problem is, thanks in advance.
  2. #2 Re: Transmission leaking fluid from the top?
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    http://www.tripleedgeperformance.com...luid-leak.html
    Fluid leak from top vent
    Fluid leak from top vent on transmission case:
    This problem was much more common to see on the earlier model years of this transmission but is still a potential problem that can happen. The cause of this problem is the upper channel plate gasket. The channel plate is a larger aluminum plate that bolts over the chain and sprocket assembly and has several fluid passages throughout it. The valve body bolts on top of the channel plate. The upper channel plate gasket has had several revisions to aid against blowout problems and the most recent paper design gasket works well. There is a passage that has line pressure flowing through it and this is just under the vent on top of the transmission case, so when it blows out you have very high pressure spraying transmission fluid straight up into the vent and it can make a big mess in a hurry. This can be repaired in the vehicle by lowering down the transmission and removing the side cover, pump, valve body, and finally the channel plate.
    Recently the aftermarket has released a Metal design channel plate gasket set which should eliminate any leakage problems as long as the case and channel plate surfaces are in good condition and the bolts are all properly torqued. The metal channel plate gaskets crush down a bit due to their design so several torque passes should be made to assure the bolts are all tight.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  1. Leaking oil or trans fluid?
    By zildjian102 in forum General Tech Discussion
    Last Post: 10-30-2010, 02:17 PM
  2. Transmission fluid leaking into radiator.
    By Fatboy58 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-04-2010, 10:24 AM
  3. 98 GTP leaking tranny fluid
    By millfire517 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-28-2009, 11:02 AM
  4. Leaking tranny fluid
    By c002529 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-24-2009, 07:00 AM
  5. Help!! Tranny leaking fluid
    By NMillis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2009, 06:48 AM
