when your check engine light goes on you can connect a code reader to that connector which in turn is connected to the car' s computer the car's computer will tell the code reader what the the problem is. also when you have your emissions done they will connect there computer to the connector to see if the car has any codes. if it does you more than likely will fail emissions.thats what the connector is for. if you open up your glove box one the right hand side there is a storage compartment, pull that out turn it around and you will see a diagram of all the fuses and where they connect to on the bottom left you will see (drl) daytime running lights yank that fuse out with the white fuse puller. if you dont have a fuse puller try ur fingers if not try some neddle nose pliers. once you have taken out the fuse your drl are disabled. before I forget make sure the car is not running when you pull out any fuse.
