Thread: daytime running lights
Results 1 to 17 of 17
  1. #1 Re: daytime running lights
    SE Level Member rojo grandprix's Avatar
    Munster, Indiana
    that black box in the picture looks to be an aftermarket alarm module. get some wire ties and secure it up high were it wont be in the way.
  2. #2 Re: daytime running lights
    Buffalo, NY
    Quote Originally Posted by rojo grandprix View Post
    eh I'll do that but the black box is heavy enough to push part of carpet away. But I'll try to bring that up too with the wire tie.
  3. #3 Re: daytime running lights
    Munster, Indiana
    when your check engine light goes on you can connect a code reader to that connector which in turn is connected to the car' s computer the car's computer will tell the code reader what the the problem is. also when you have your emissions done they will connect there computer to the connector to see if the car has any codes. if it does you more than likely will fail emissions.thats what the connector is for. if you open up your glove box one the right hand side there is a storage compartment, pull that out turn it around and you will see a diagram of all the fuses and where they connect to on the bottom left you will see (drl) daytime running lights yank that fuse out with the white fuse puller. if you dont have a fuse puller try ur fingers if not try some neddle nose pliers. once you have taken out the fuse your drl are disabled. before I forget make sure the car is not running when you pull out any fuse.
  1. How to disable my day time running lights ??
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2010, 08:54 PM
  2. who is running E85?
    By Bio248 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 06:25 PM
  3. How to turn off daytime running light on 2008 GP
    By timc in forum General Tech Discussion
    Last Post: 02-06-2009, 01:51 PM
  4. Daytime running lights
    By Girevik in forum General Tech Discussion
    Last Post: 01-05-2009, 12:40 PM
  5. Running Hot
    By 1998xGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2008, 10:41 AM
