Thread: Newest issue: Reverse lights!
Results 1 to 16 of 16
  1. #1 Re: Newest issue: Reverse lights!
    You say yours stopped before the switch... can you elaborate on that please.
    In looking at the 7 pin connector there is power in and then the reverse lights output from that same connector. To test, I'd check there is power in at the orange wire and after blocking the wheels and putting it in reverse with engine off you should have output on the reverse lights pin. If you aren't getting power in...that's likely your issue. If you do have it and don't have power out then it's the switch or the adjustment of the switch. If you have output to that reverse wire and nothing at the back of the car, that's a long way to trace the wiring.
  2. #2 Re: Newest issue: Reverse lights!
    SE Level Member ThatOldCarSmell's Avatar
    Apr 2020
    Upstate SC
    Right, by stopped, I mean that the issue I was having all the time if the key was on......stopped. I had plugged both bulbs back in "just to see" after checking the wiring where I did, and getting the water out of the rear floor pan, and they did not come on with keyed power. Then when in reverse, they came on, as in functioning properly. So I stopped even messing with it at that point.
    So *IF they are currently functioning properly, then there should be power at the orange wire and at the reverse lights pin ( I believe light green wire) when the car is in reverse. I would think that under all circumstances there would be hot at the orange wire when the key is on, assuming the reverse lights come on at all right? it would just be a matter of whether it was lighting up (getting power at the b/u pin) beyond when it's supposed to, indicating the switch.
    Then again, like a lot of folks, circuit trouble shooting has never been my favorite, so I could be 100% incorrect....
    99 GTP:
    ZZP FWI , ZZP 3" catted DP, Resonator delete,The occasional Poly bushing, ZZP front sway Bar, NGK TR6's, LED Headlights, 180* TStat, Anti- pogo washers ...This list seemed a lot longer before I started typing....
  1. Replaced tail lights, now reverse lights dont work
    By USonuMabeaCh in forum Audio, Security & Visual Electronics
    Last Post: 03-04-2016, 01:02 PM
  2. 04+ HID reverse lights
    By hockeybawler in forum Visual/Body Modifications
    Last Post: 04-24-2015, 10:05 AM
  3. LED Reverse Lights
    By sjw515 in forum Visual/Body Modifications
    Last Post: 04-23-2015, 04:36 PM
  4. LED reverse lights?
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 01-13-2013, 06:36 PM
  5. 04+ HID Reverse Lights
    By Dthreap in forum 04+ Specifics
    Last Post: 03-22-2012, 10:28 PM
