Thread: Replaced tail lights, now reverse lights dont work
Results 1 to 6 of 6
  1. #1 Replaced tail lights, now reverse lights dont work
    SE Level Member USonuMabeaCh's Avatar
    Sep 2015
    gulf breeze, fl
    I got the spyder tail lights, and installed them, everything works except the reverse lights, they only thing i did was twist them out of the old light housings and then twist them into the new ones...
    Any ideas?
    02 40th GTP 2dr SSEI IC ZZP system with 3.2" Wizaird CAI Transgo SK SD headers aeroforce w/WB 1.9s over kill tune | 70 Skylark 455 bored to 462 Stg 1 iron heads ported 270 in 205 ex spx intake 870 street avenger 2" headers 3" xpipe flowmaster 40's full msd ign custom cam 540 hp 560 lbft TH400 2800 stall hotchkis susp DTS 12 bolt 3.42 rear
  2. #2 Re: Replaced tail lights, now reverse lights dont work
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Are they spyder LED tails? I have them never had any issues with them try a new bulb.....
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  3. #3 Re: Replaced tail lights, now reverse lights dont work
    Jul 2010
    Coquitlam,BC,Canada
    They are plug-n-play. Put car in reverse, check the vehicle harness at the lights to make sure you are getting power, then check the light to see if power is getting to it. I suspect you might have some bad lights.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Replaced tail lights, now reverse lights dont work
    Sep 2015
    gulf breeze, fl
    one of the bulbs was in backwards, the other was simply burnt out... that said the wires are loose, the passenger side stopped working after i put it back on, but i took it back off and fiddled with it and now it's working.
    BTW... Napa says that the bulb for the reverse is a 3156, the old one that had burnt out (but had worked for the year and a half that ive had the car at least) was a 3157... Im not a parts guy, did someone just put the wrong bulb in, or is there little practical difference between the two?
  5. #5 Re: Replaced tail lights, now reverse lights dont work
    Jul 2010
    Coquitlam,BC,Canada
    Nice easy fix.
    Look inside the glass and you will see the difference; 3156 is a single filament, 3157 is a dual filament. You can use a 3157 in place of a 3156 (if needed), but not the other way around.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: Replaced tail lights, now reverse lights dont work
    GTP Level Member
    springfield IL
    put a cree bulb in for the back up lights... i had nothing but problems with those spider tail lights... burnt out and/or broke off
  1. Help REAR TAIL LIGHTS NOT WORKING, BUT BRAKE LIGHTS WORK.
    By shihiran in forum General Tech Discussion
    Last Post: 10-21-2012, 02:35 PM
  2. 2007 GXP No gears work and reverse lights dont work
    By MikeJenkins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2012, 06:05 AM
  3. 97-03 Tinting Tail Lights Except Reverse White Light
    By 3CLiPSE in forum Visual/Body Modifications
    Last Post: 02-02-2012, 05:21 PM
  4. No tail lights but brakes work just fine??
    By Strummin365 in forum General Tech Discussion
    Last Post: 09-02-2011, 10:36 PM
  5. no reverse lights and trunk popper don't work
    By frankdatank0 in forum General Tech Discussion
    Last Post: 04-09-2009, 10:06 PM
