#1
Racing, and power steering.
Hey friends.
I plan on taking my 01 GTP to Thunder Hill raceway for a track day down the road.
The car is ready to go at this point, however I don't trust that the power steering will hold up without grenading. Do these cars just have weak pumps? Is there anything I can do to make sure it can make it through a whole day of track use?
Thanks!
#2
Re: Racing, and power steering.
10-03-2020
this a road course or a drag strip? either way cant see the p/s pump being a issue.
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#3
Turbo is the way to go.
10-03-2020
It's the fluid temp I'd be worried about on a road course. A cooler for the fluid would go a long way.
Post Thanks / Like - 1 Thanks, 0 Likes, 0 Dislikes
#4
10-03-2020
The impala police package cars had a factory cooler etc that can sometimes be found a junkyards for little money
#5
Thank you for the input!
@Scotty: Yes it's a road course. Both my 97 and my current 01 seem real eager to make unhappy p/s noises. I had the rack replaced about 10k ago. Perhaps I just need a new pump, or maybe they are all noisy from time to time?
I'd definitely be interested in a cooler! Are there any kits out there?
Also could you say, put on a larger pully to underdrive the power steering? Would that lower the stress on it?
#6
I'd worry more about brakes than steering. Be sure you have new pads and rotors and bring an extra set for changeout afterwards. I know of someone who burned up a caliper on a road course.
"Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
#7
Thank you for the reminder. I have new 12" rotors up front, and new pads all around. Although I am using DOT 3 fluid. Is there any disadvantage to running dot 4/5 etc?
#8
DOT4/5 are actually better for racing. They have a substantially higher boiling point, which is a huge enemy in racing. Dot4 is around 450* and Dot5 is around 500*; whereas Dot3 is around 400*.
If you're going to run them, you have to do a complete flush though, the chemical makeup is different.
