Thread: Conversion
Results 1 to 12 of 12
  1. #1 Conversion
    Jan 2019
    Not sure where to put this post in these forms I apologise if it is in the wrong location. I'm curious if the awd transmission from a Montana 3.4 will bolt up to the 3.8 series 2 motor. I have a 2002 gtp and was thinking on using the rear axle and transmission from a Montana to convert to awd. Has anyone else tried this? If so, any tips on the conversion?
  2. #2 Re: Conversion
    Oct 2014
    portland oregon
    Wooweemomma. I dont know how that would even work without some major fab work.. I like where your going having a all wheel drive gtp
    Sent from my SM-N920V using Tapatalk
  3. #3 Re: Conversion
    Where will the drive shaft go?
    If it's a 4T65e, the bolt pattern is the same but that doesn't mean it'll fit on the W-body subframe.
  4. #4 Re: Conversion
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I know from experience that the montana subframe bolts directly up to the grand prix. Main difference is that it has the mounts for the 3.4. Probably would be best to lay the two subframes side by side and see where they've modified it to clear the driveshaft.
    As far as the transmission, yes, it will directly bolt up. The main issue is that at least on the aztek's the body control module plays a part in controlling the awd. Not to mention, that there is not tuning support from hptuners for this. You could try messaging them, but I doubt they would go through the trouble unless you're willing to pay through the nose.
    I'm sure if you beat on the underside of the car enough you could get it to fit after a LOT of fabricating, but the rear would be really tricky to fit in there. I'd probably look more into the aztek/rendezvous with the independent suspension/air ride if you're going through the trouble.
    The biggest issue is that these things were never designed to take any power whatsoever. They frag on the stock 3.4. They're really just not built well. Personally I wouldn't waste my time on it, but it would definitely make a good project albeit futile!
  5. #5 Re: Conversion
    Mar 2018
    NY
    GM made a concept car in the early 00's called the G8 (not to be confused with the Commodore G8). It was a Grand Prix with an LS1 and the versatrak AWD same as used in the Montana & Aztek. The system did not hold up to the power of the LS1 very well, but they did fit it in the 97-03 Grand Prix body.
  6. #6 Re: Conversion
    Oct 2014
    portland oregon
    http://www.2040-cars.com/Pontiac/G8/...ro-pow-911439/
  7. #7 Re: Conversion
    Oct 2014
    portland oregon
    pretty slick
  8. #8 Re: Conversion
    Jan 2014
    AR
    Quote Originally Posted by wowitsfast View Post
    pretty slick
    It does look cool. I can dig it. Too bad the pics don't show anything but exterior body work. When the just RWD conversion stuff comes up, I usually say buy a same year Camaro, put it in the garage next to a GP and a welder and don't come out until done. Looks kinda like what GM did there but yeah with Montana junk. However, in any case, the very best that anyone can end up with is still a Grand Prix. Those take you a mile down a road just like Bugattis and bicycles do.
  9. #9 Re: Conversion
    Oct 2014
    portland oregon
    Quote Originally Posted by idrivejunk View Post
    I know why the general didn't put it into the market place. Bottom line is they could never warrantee it. You can't put a real deal power plant in a car and have pos components behind it and put it into service.. However like you said IDJ I can dig it.
  10. #10 Re: Conversion
    Jan 2014
    AR
    Yep, that. And insurance throttles the world. Hellcats and such slide in under the radar but Pontiac made nowhere near enough stuff to offset a few wild hairy beasts like that is. Not in them days. But she's a looker and I bet it yanks pretty hard. Definitely more to that ride than meets the eye, at a glance.
  11. #11 Re: Conversion
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    That car's still in a museum. Just supercharge a Montana, which has been done, and keep your feet on the ground.
    All that work to drive around a straight-piped ****box with rusted rockers, blown struts and a spray painted dash ain't worth it. If a person was going to spend that much time and money, just buy an already AWD car with boost like an audi or something.
  12. #12 Re: Conversion
    Oct 2014
    portland oregon
    Quote Originally Posted by SaukRapids View Post
    So what your saying is..... "it's totally doable" lol
  1. 04+ power passenger seat conversion/ driver's fold conversion
    By wstefan20 in forum General Grand Prix Discussion
    Last Post: 04-04-2020, 01:15 PM
  2. E85 Conversion... Now I have KR?
    By blackgtp95 in forum PCM Tuning
    Last Post: 08-11-2013, 05:20 AM
  3. Conversion
    By Nathan07GP in forum Introductions/Noob Questions
    Last Post: 03-06-2012, 01:56 PM
  4. HID conversion
    By rcranium in forum Audio, Security & Visual Electronics
    Last Post: 03-14-2011, 08:37 PM
  5. RWD conversion
    By flash527 in forum General Tech Discussion
    Last Post: 08-14-2009, 10:01 AM
