Thread: E85 Conversion... Now I have KR?
Results 1 to 9 of 9
  1. #1 E85 Conversion... Now I have KR?
    SE Level Member blackgtp95's Avatar
    Jun 2011
    Toledo,OH
    I just converted to E85 this week and I now have 1-3 degrees of knock on my 3.4 pulley when I used to have 0 on my 3.2 pulley
    Doesn't seem to make sense to me
    Here is my tune
    https://dl.dropboxusercontent.com/u/...E85%20Tune.hpt
    and here is my 40 min scan (WOT towards the last 10 mins)
    https://dl.dropboxusercontent.com/u/...040%20mins.hpl
    I am fairly new to tuning but I though everything I did was correct
    I scaled my 60# injectors to 42 and that is it, I had the commanded AFR at 11.7 but when I saw 8 degrees of know I moved it back to 11.0
    I should note Histogram 10 is my Wideband
    Any help would be appreciated as I though E85 was a super knock suppressing fuel.....
  2. #2 Re: E85 Conversion... Now I have KR?
    Stock pump?
  3. #3 Re: E85 Conversion... Now I have KR?
    Nov 2011
    NY
    Stock pump?
    or at least a fuel pump Rewire... : )
    (just thought to add that, hehe)
  4. #4 Re: E85 Conversion... Now I have KR?
    Jun 2011
    Toledo,OH
    Stock pump?
    No it is a walbro pump
    The strangest part of this is my LTFT are locked at 0.0 all the time and I am not commanding Open Loop
  5. #5 Re: E85 Conversion... Now I have KR?
    Jun 2011
    Toledo,OH
    no one has anything for me ? not even a hint?
  6. #6 Re: E85 Conversion... Now I have KR?
    May 2012
    Albuquerque, NM
    Change back to gasoline?! :-/
  7. #7 Re: E85 Conversion... Now I have KR?
    Feb 2009
    flintnasty MI
    what was your commanded timing during and before the KR?
  8. #8 Re: E85 Conversion... Now I have KR?
    Jun 2011
    Toledo,OH
    Apparently my tune file was somehow corrupted.... Not really sure went back to an old tune from a few years ago and did "Write Entire" instead of just calibrating and I now have LTFT again and only 1 degree of KR
    I will update after I dial in my LTFT's after I do some logging as they are pegged at 16.4 and after cruising for 20 mins they are going to 10.4 which is terrible and they are not locking at 0.0 when WOT
    Thanks
  9. #9 Re: E85 Conversion... Now I have KR?
    SE Level Member Casper00693's Avatar
    May 2011
    Orlando, FL
    What I did was take the 42.5 inj tables and i added 30% fuel to the IFR table, i adjusted my commanded AFR to 12.2 and i never touched the MAF either but also considered doing some PE adjustments, im not sure why you are knocking on a 3.4 on e85 if u did not knock on a 3.2 i want to say you should review your fuel tables and see where you may have missed something. I was actually able to up my timing quite a bit. And im top swapped on a 3.4mps . view signature. I am running 19* timing WOT w/0*KR I have room for more. When I first messed with E85 i **** myself cause i blew a head gasket! Lets just say i didn't know wtf i was doing when i first messed with E85, so i did some more studying while i switched back to 93 octane again. And now I love it and i love my mpg im getting as well.
    I couldn't begin to give you advice on the hpt tuning as I use DHP. But I have a feeling you need to really just take the #60 tables and ADD 30% to the IFR tables. Good luck.
    L67 bottom end-3.29's-3.3mps-42.5's-E85-SD headers-DHP Tune my own-Gen V-18* timing-AL 104s.
    Soon: Stage 3 p&p heads, 1.9s and #90s.. All sitting for no reason just need installed.
  1. conversion GT-->GTP
    By biggt in forum General Tech Discussion
    Last Post: 03-28-2011, 06:44 AM
  2. conversion?
    By 02gtp40 in forum Visual/Body Modifications
    Last Post: 06-13-2010, 12:08 AM
  3. ZZP's HID Conversion Kit
    By BwolfGT in forum Visual/Body Modifications
    Last Post: 01-03-2010, 11:19 AM
  4. RWD conversion
    By flash527 in forum General Tech Discussion
    Last Post: 08-14-2009, 10:01 AM
  5. gt conversion to s/c
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2008, 10:52 PM
