Vince,
Sorry it has taking me so long to get you an update I have been wanting to post this for some time to help others that want to restore these cars. I'm hoping you can post some pics of the panels you bought for comparison.
You said you are ordering inner rockers. The above panel. is the Inner Rocker reinforcement seen here
Here are a couple of different angles of the new ones I showed you earlier.
This is the Inner Rocker panel.....
Before
Almost complete. After fabricating come of the pieces. Just have to weld in and epoxy prime....
So, most likely you are going to need the inner rocker, the inner rocker reinforcement and of course the outer rocker panel. The outer rocker panel was originally part of the Uniside which is basically the whole side of the car. That's how the car was originally assembled. The only way to buy just the Rocker Panel itself is from the aftermarket. Here are some part numbers from different aftermarket suppliers that I found for my 2dr.
Rocker Panel Repair
  • Rocker Panel(Aftermarket) - 2 Door
    • Sherman
      • Left - 844-03L
      • Right - 844-03R
    • RayBuck
      • Left - 0830-101
      • Right - 0830-102
    • Mill Supply, Inc.
      • Left - 665-97-40-LH
      • Right - 665-97-40-RH
