Thread: Calling all experts on a headlight problem
Results 1 to 10 of 10
  1. #1 Calling all experts on a headlight problem
    Mar 2013
    Canada
    I have a 2008 GP and few weeks ago when I turn off my car the headlight still remained on. I tried turning it off from the switch but that didn't work. Put the key back in the ignition and toggled it to the ACC and off position and after few times it turned off. Just today it happened again, did the same solution but didn't work. I locked and unlocked the door with the FOB and it eventually turned off. Can it be a fuse issue? I read somewhere that someone replaced the HDM low beam relay that is in slot #35 and that worked. Any ideas will be much appreciated.
    Sent from my SM-G935W8 using Tapatalk
  2. #2 Re: Calling all experts on a headlight problem
    Nov 2012
    Madison
    Sounds like how a stuck relay would act.
    Might be your best bet to replace the $35/#35 fuse
  3. #3 Re: Calling all experts on a headlight problem
    Mar 2013
    Canada
    It's funny I changed the same relay switch maybe a year ago but for not having headlights at all. I used a knockoff brand maybe that's why.
    I had a look and sure enough the part was replaced, I no longer have the part number on the fuse as I replaced it with a noname one. Can someone give me the number on the fuse. Is it this one?
    https://www.amazon.ca/ACDelco-150167.../dp/B0065S6S8Y
  4. #4 Re: Calling all experts on a headlight problem
    Nov 2016
    Grove City, OH
    It could be as simple as a setting in the trip computer. I have an option to have my exterior lights stay on when you turn your car off for a selected amount of time. (15, 30, 90 seconds)
    2004 Pontiac Grand Prix GTP Competition Group
  5. #5 Re: Calling all experts on a headlight problem
    Mar 2013
    Canada
    No because it doesn't happen all the time and normally it turns off right away. I will change the part and see what happens.
  6. #6 Re: Calling all experts on a headlight problem
    SWPA
    Definitely sounds like a stuck HDM relay. Its just stuck the opposite of how others decide to stick.
  7. #7 Re: Calling all experts on a headlight problem
    Mar 2013
    Canada
    K picking the park up on Monday, anybody have the number on the relay as I already replaced it and it no longer has the number on the part.
  8. #8 Re: Calling all experts on a headlight problem
    Nov 2012
    Madison
  9. #9 Re: Calling all experts on a headlight problem
    Quincy, Mass
    I've had my hid harness get corrosion where the relay plugs in and cause this, had to replace the harness. After it happening a few years in a row I spent the money and got them from theretrofitsource and haven't had an issue since.
    No more GP 04 Impala SS Indy:
  10. #10 Re: Calling all experts on a headlight problem
    Mar 2013
    Canada
    Quote Originally Posted by spazzz View Post
    15016745
    Thanks
  1. Calling all electronics experts! Capacitors
    By J57ltr in forum Off Topic Discussion
    Last Post: 07-22-2015, 09:59 AM
  2. 06 gxp headlight problem
    By dnfd737 in forum General Tech Discussion
    Last Post: 06-03-2013, 06:19 PM
  3. Headlight problem
    By daytonshouse in forum Introductions/Noob Questions
    Last Post: 04-23-2012, 02:21 PM
  4. BIG headlight problem, need help!!!
    By IndyGTP in forum General Tech Discussion
    Last Post: 11-05-2009, 03:16 PM
  5. headlight/fog problem
    By riceburner in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2009, 09:29 PM
