Thread: Sheet metal intake?
Results 1 to 20 of 21
  1. #1 Sheet metal intake?
    Oct 2011
    Puyallup WA
    Does anyone still make them? kinda wanted to go that route instead of swapping to my l26
    08 G8 GT - exhaust Tune
  2. #2 Re: Sheet metal intake?
    find a local fab shop. it's a fairly simple thing to create.
  3. #3 Re: Sheet metal intake?
    Pointless holden ones are forsale for 200 bucks on here back a few pages in the fs section just mod the top hat so the tb is on the side not the front done....... Or you could always use a f body intake.
    I dont really see a sheetmetal one being worth the cost. Esp if its not essential for clearance like the 4th gen f body guys run into for example.
  4. #4 Re: Sheet metal intake?
    Oct 2011
    Puyallup WA
    I like the sheet metal for the fact that you can reverse it easily when I demod someday...planning on getting a vette at some point
  5. #5 Re: Sheet metal intake?
    Im lost how is a sheet metal intake for a 3800 related to a vette? Reverse as in how?
  6. #6 Re: Sheet metal intake?
    Oct 2011
    Puyallup WA
    Because when I buy a vette I will demod my car to sell it and not pulling the lower lim again to put the sc back on is what I was talking about...common use your brain
  7. #7 Re: Sheet metal intake?
    http://stattama.com/index.cfm?fuseac...&pageid=43here there ya go a little bit of explanation would have gone a long ways lol.
    Stattama makes sheetmetal intakes that only fit a supercharger lim.
  8. #8 Re: Sheet metal intake?
  9. #9 Re: Sheet metal intake?
    Oct 2011
    Puyallup WA
    I was just teasing you man...thanx that's what I was looking for
  10. #10 Re: Sheet metal intake?
    I meant that as to make a duplicate orrrrrr how about call them that would be a hell of an idea!
    Geezus sorry i didnt bring my coloring crayon today...........
  11. #11 Re: Sheet metal intake?
    right, i don't think they make them anymore.
    making a copy of it seems like it'd be cake, though. there's not much to it.
  12. #12 Re: Sheet metal intake?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    I looked at the ones everyone else has made and just built my own, not to hard if you have or know someone with access to welder/machine shop...if not the cost may out weigh the work involved to swap out the LIM when you demod.
  13. #13 Re: Sheet metal intake?
    Simple trace a gasket cut plate to match weld up a box drill a hole in it same size as tb opening tap a few holes for the tb.
    Ohh and save about 400 bucks over the stattama price....
    Edit what he said^^^^^^ what do a set of cheapo plastic lim gaskets cost? plus a na intake will flow way better than some crude box slapped on a sc lower intake!
  14. #14 Re: Sheet metal intake?
    Oct 2011
    Puyallup WA
    Wow everyone is angry today...machine shop and welder is available to me so I will look into the cost of making one if it's to much hassle will use my l26 intake
  15. #15 Re: Sheet metal intake?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by wa04compg View Post
    Getting off topic but as for vettes.... I have had and built a few C5s and bang for your buck... they will change your life
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  16. #16 Re: Sheet metal intake?
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    I was able to obtain a Stattama intake a long time ago. I had a gutted SC with block off and the Stattama intake made a difference.
    I think a custom intake will be and is the best option for flow IMO. It's a straight forward design and the air goes straight in.
    Here are some pics to help give you reference if you want to make one.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  17. #17 Re: Sheet metal intake?
    Oct 2011
    Puyallup WA
    Thanx man! Looks like it would be pretty simple to make
  18. #18 Re: Sheet metal intake?
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Thanks for the pictutes, Sal! That's helpful.
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  19. #19 Re: Sheet metal intake?
    Feb 2008
    NY
    Quote Originally Posted by WhiteLightningGTP View Post
    No prob
    The l67 lower intake sucks balls
    I don't have a problem with mine
  20. #20 Re: Sheet metal intake?
    hangover park IL
    ~James~ Psychotic Gearhead
  1. Metal lower intake manifold for 05 GP GTP
    By HEADWEST in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2013, 06:31 AM
  2. Factory build sheet location?
    By txslow6 in forum General Grand Prix Discussion
    Last Post: 07-14-2012, 12:43 PM
  3. What year did the factory start using the metal frame intake gasket?
    By Gasnmyveins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2012, 12:32 PM
  4. metal on metal sound
    By Toms04compg in forum Brakes/Suspension/Chassis
    Last Post: 03-21-2012, 04:54 PM
  5. Carbon Fiber sheet?
    By robahr24 in forum General Tech Discussion
    Last Post: 08-24-2008, 04:39 PM
