Thread: No backup lights
Results 1 to 20 of 27
  1. #1 No backup lights
    GTP Level Member
    Jun 2016
    Cleveland ohio
    My backup lights are not working. The fuses are good and I’m not getting power to the harness. Where in the heck is the sensor on these? I’ve never had this issue on any of my past Prix. Any help appreciated.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: No backup lights- 2007 GT
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Mods- I meant to post this in general section. Sorry
  3. #3 Re: No backup lights- 2007 GT
    check the trunk harness it likes to break where it comes through the body by the hinge.
  4. #4 Re: No backup lights
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    By no power, where did you measure? It's very common for the wires to corrode through several inches. Test the wire on the right rear tail a few inches back.
  5. #5 Re: No backup lights
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I tested at the harness in the trunk that attaches to the backup lamp bar.
  6. #6 Re: No backup lights
    Aug 2017
    Raytown, MO
    Strange... best place I've found for schematics on our cars is actually autozone. Just register for a free account, search under repair guides, wiring diagrams and there's the diagrams for literally every system in both newer gens of our GPs! Watch out, some of the colors may not be correct, but if you can read the connector positions, I've never seen one wrong yet! I'll take a look some-time and see what I can think of.
    In the meantime, are there any other issues or lights (especially interior) that are not functioning properly?
  7. #7 Re: No backup lights
    Aug 2017
    Raytown, MO
    Looks like the bcm controls the backup lamp relay. Probably under the driver's dash, but I'm sure someone will chime in on the exact location.
    Before I tested that, I would do a power drop test to test the ground to make sure you don't have a bad ground to the lamp, but I wouldn't think so since pretty much the whole rear end is tied to that ground.
    Here's the schematic I found on autozone for the backup lamps for an 05 which should be the same. If the ground is good, I'd test the relay.
    No backup lights Attached Images
  8. Thanks rickisrad thanked for this post
  9. #8 Re: No backup lights- 2007 GT
    Aug 2017
    Raytown, MO
    There's no direct sensor for these. They are triggered through the bcm indirectly by the range selector switch, but there's a relay that controls the lamp inbetween. I'd test for good ground, then go on to test the power coming from the relay. If that's good, I'd test the continuity of the power wire and then have fun locating the break. Might just be a bad relay though. Posted the schematic on your other post if you want to check it out. Autozone has all the schematics you'll ever need.
  10. #9 Re: No backup lights
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Thanks guys. I will check these things out soon. This winter storm is bad right now. Went from 57 to 22 in a few hours. Went from heavy rain to solid ice and now snow covering it all. Gotta love it.
  11. #10 Re: No backup lights
    i replied in the first thread, no idea if you ever looked back at it.
    its the trunk harness, where it goes through the body near the hinge. open that up and you'll find a bad wire, theres also a plug in the trunk to unplug the harness, that plug might be boogered up. the lic plate lights work? if not its the harness too.
  12. #11 Re: No backup lights
    GTP Level Member
    Jun 2016
    Cleveland ohio
    First thread? Is there two of them? Weird. As soon as I can get into the trunk to look I will check that out. Everything is frozen shut with ice now. Thanks!!
  13. #12 Re: No backup lights
    No backup lights- 2007 GT aka your first thread.
  14. #13 Re: No backup lights
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Lol. I didn’t make 2. A mod might have moved one and didn’t delete the original. I will try to delete the one with the least replies.
  15. #14 Re: No backup lights
    you made two in the tranny section. either way, that harness is a very common failure point for anything mounted in the trunk thats not working.
  16. Thanks rickisrad thanked for this post
  17. #15 Re: No backup lights
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I will definitely check that out.
    It it must have been a glitch. I didn’t purposely make two threads. I’m trying to figure out how to delete one of them. I might have to do it on my PC instead of phone???
  18. #16 Re: No backup lights
    you cant delete em. only mods can. dont matter, get to hunting on that harness lol
  19. #17 Re: No backup lights- 2007 GT
    Mar 2014
    Tucson
    Quote Originally Posted by rickisrad View Post
    Moved.
  20. #18 Re: No backup lights
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Thanks Brandon.
    I went out to trace the wires and and it is too darn cold out. I will have to move some crap out of the garage so I can get the car into some heat.
  21. #19 Re: No backup lights
    on my regal the plug is behind the side cover, follow it inside, unplug it, then pull it out the grommet, open the loom starting where it looks pinched, cause thats where the busted wire will be found.
  22. #20 Re: No backup lights
    Nov 2012
    Madison
    License plate bulbs must not work either.
    I'm no good because I painted my reverse bar black topped with a clear coat.
  1. installing backup camera
    By Harbinger207 in forum Audio, Security & Visual Electronics
    Last Post: 07-14-2017, 04:19 PM
  2. Backup camera
    By Paul007 in forum General Grand Prix Discussion
    Last Post: 05-31-2016, 11:29 AM
  3. LED DRL's as backup lights?
    By TateBongard in forum General Tech Discussion
    Last Post: 09-12-2014, 08:57 PM
  4. No backup lights, trunk release and fuel level is always reads full
    By dhallstead in forum General Grand Prix Discussion
    Last Post: 09-08-2013, 12:31 AM
  5. electrical help no trunk release, backup lights
    By BIGGRASS in forum General Tech Discussion
    Last Post: 08-03-2009, 06:53 PM
