My backup lights are not working. The fuses are good and I’m not getting power to the harness. Where in the heck is the sensor on these? I’ve never had this issue on any of my past Prix. Any help appreciated.
By no power, where did you measure? It's very common for the wires to corrode through several inches. Test the wire on the right rear tail a few inches back.
I tested at the harness in the trunk that attaches to the backup lamp bar.
Looks like the bcm controls the backup lamp relay. Probably under the driver's dash, but I'm sure someone will chime in on the exact location.
Before I tested that, I would do a power drop test to test the ground to make sure you don't have a bad ground to the lamp, but I wouldn't think so since pretty much the whole rear end is tied to that ground.
Here's the schematic I found on autozone for the backup lamps for an 05 which should be the same. If the ground is good, I'd test the relay.
Strange... best place I've found for schematics on our cars is actually autozone. Just register for a free account, search under repair guides, wiring diagrams and there's the diagrams for literally every system in both newer gens of our GPs! Watch out, some of the colors may not be correct, but if you can read the connector positions, I've never seen one wrong yet! I'll take a look some-time and see what I can think of.
In the meantime, are there any other issues or lights (especially interior) that are not functioning properly?
Thanks guys. I will check these things out soon. This winter storm is bad right now. Went from 57 to 22 in a few hours. Went from heavy rain to solid ice and now snow covering it all. Gotta love it.
i replied in the first thread, no idea if you ever looked back at it.
its the trunk harness, where it goes through the body near the hinge. open that up and you'll find a bad wire, theres also a plug in the trunk to unplug the harness, that plug might be boogered up. the lic plate lights work? if not its the harness too.
First thread? Is there two of them? Weird. As soon as I can get into the trunk to look I will check that out. Everything is frozen shut with ice now. Thanks!!
Lol. I didn’t make 2. A mod might have moved one and didn’t delete the original. I will try to delete the one with the least replies.
I will definitely check that out.
It it must have been a glitch. I didn’t purposely make two threads. I’m trying to figure out how to delete one of them. I might have to do it on my PC instead of phone???
Thanks Brandon.
I went out to trace the wires and and it is too darn cold out. I will have to move some crap out of the garage so I can get the car into some heat.
on my regal the plug is behind the side cover, follow it inside, unplug it, then pull it out the grommet, open the loom starting where it looks pinched, cause thats where the busted wire will be found.
The license plate bulbs do work fine.
-Scotty, I think the 04+ might have a different routing. I do not see what you are talking about on my car. I traced the wiring until the rear speaker deck. I need to remove the seat to get to the rest of the harness. I know it runs under the side moldings. Its been too cold and snowy to have the car torn apart. It is supposed to be a bit warmer this weekend.
Is there a switch at the gear selector that triggers the backup lamps? I may remove the center console to check if something there is all gunked up.
theres got to be a plug you you cant take the trunk lid off with out cutting the wires. it could be wrapped in black tape.
if your not seeing the plug, just open the loom up and look for a damaged wire. the damage is where the hinge likely touches the wire loom.
I have an update on this issue. long story short is the led bulbs were in the wrong way. :/ lol. Thanks again for all the the help guys!
Yup. Would've mentioned to try that if I knew you were using leds and that it started when you swapped bulbs. Leds are light emitting Diodes. Diodes allow electricity to go one way. Therefore, they only work in one direction. Glad you got it working though
