Scottydoggs
thats not where the hose goes. you pcv nipple on the side of the blower goes there. the valve cover hose needs to be in a nipple post maf, if thats a N* theres a nipple you can use. if not you drill and tap the brass plug under the l67 tb.
aka your doing it all wrong there. post a pic of the pcv port near where the egr would be. theres a evap port right there too that should have been sealed off if its not hooked up and being used.
