Thread: Strange Rattle Noise?
Results 1 to 5 of 5
  1. #1 Strange Rattle Noise?
    Apr 2014
    Central NJ
    Hi everyone, My 2004 GTP has been making a strange rattle noise at low rpm. It only seems to happen at around 2k rpm in any gear. It will make the noise in Park, but only for a split second. I'm not mechanically inclined at all. All I know how to do is change the oil. I've listened to what rod knock sounds like on youtube and it doesn't sound like that at all. I thought it was the heat shield, but that wasn't it either.
    Here is a video. You can hear it intermittently throughout. Ignore the the brake squeak lol.
    https://www.youtube.com/watch?v=13pm...ature=youtu.be
    Any ideas?
    Thanks for the help
  2. #2 Re: Strange Rattle Noise?
    check the belt pulleys, remove the belts, hand spin all pulleys. you looking for one that dont spin free or has a gritty feel when turning it, also check the ac clutch ring the belt rides on. one way to eliminate the ac is does it make the sound when the ac is on? (only if the ac works)
  3. #3 Re: Strange Rattle Noise?
    Apr 2014
    Central NJ
    Thank you for the suggestion, but I feel like it might be something under the car or even possibly transmission related . Not that I have much knowledge on the matter, but all pulleys are fine except water pump has a bit of a wiggle. The water pump gives more of a squeak though. The sound in question sounds almost like a hollow rattle; similar to a tin can rotating inside another tin can.
  4. #4 Re: Strange Rattle Noise?
    Nov 2012
    Toronto, Ontario, Canada
    Bang on your exhaust. Maybe you have a bad converter?
  5. #5 Re: Strange Rattle Noise?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Front control arm bushings
  1. Strange noise
    By TheDarkAngel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-16-2014, 06:20 AM
  2. Strange rattle/knock
    By BD3511 in forum General Tech Discussion
    Last Post: 06-21-2013, 07:46 PM
  3. Terrible Rattle Noise Coming From Belt Area
    By lsmith3200 in forum Introductions/Noob Questions
    Last Post: 06-17-2011, 07:18 PM
  4. Strange vibration/rattle... 02GTP
    By shredaspud in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 02:23 AM
  5. Supercharger noise, rattle HELP!
    By Mvfootball1 in forum General Tech Discussion
    Last Post: 08-26-2010, 04:49 PM
