Thread: need caliper bracket bolt spec
Results 1 to 3 of 3
  1. #1 need caliper bracket bolt spec
    AZ
    Need the size/pitch of the rear brake caliper bracket bolts (bracket to suspension, not caliper to bracket). Also what grade of bolt. I rounded off one of mine. Thanks.
    2001 GP non-SC, 125K miles.
  2. #2 Re: need caliper bracket bolt spec
    take it to a hardware store, find a nut that fits the old bolt, you now know what bolt you get by the nut's specs. grade 5 should be ok. 8 is always best tho.
  3. #3 Re: need caliper bracket bolt spec
    AZ
    Well I'd like to know the size before taking it apart. I rounded off the old bolt the last time I had it apart, was able to use it though, figure it'll get even more chewed up when it's removed again. Anyone know?
  1. Bolt size and torque spec thread.
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-18-2016, 07:12 AM
  2. Caliper Bracket Bolt Falling out
    By REDLION in forum Brakes/Suspension/Chassis
    Last Post: 06-08-2011, 06:55 PM
  3. Caliper Mounting Bracket Bolt
    By Paintball0027 in forum Brakes/Suspension/Chassis
    Last Post: 10-28-2010, 11:14 AM
  4. caliper bracket
    Last Post: 08-16-2009, 02:04 PM
  5. caliper bracket
    By gotboost3 in forum Brakes/Suspension/Chassis
    Last Post: 02-11-2009, 08:44 PM
