Thread: Stalling and Banging into Gear After TC Lockup
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Stalling and Banging into Gear After TC Lockup
    GTP Level Member
    Aug 2012
    st louis park, MN
    Guys and Gals, I recently replaced my transmission lines which went pretty well but now the lines are leaking at the fittings where they go into the pan. I gave them each a good tug and they seem to be in there well.
    Is there a rubber seal or something where the line goes in that could need replacement? Or could there be a need to replace the fittings going into the pan.
    I fixed a leak but a couple more sprung
    EDIT: 2008 Base grand prix
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  2. #22 Re: Stalling and Banging into Gear After TC Lockup
    GTP Level Member
    Aug 2012
    st louis park, MN
    I'd really appreciate any thoughts on why the lines/fittings could be leaking at the transmission after a new line install. They were fine before - Let me know if you have anything to offer.
  3. #23 Re: Stalling and Banging into Gear After TC Lockup
    GTP Level Member
    Aug 2012
    st louis park, MN
    Quote Originally Posted by stocker View Post
    Anyone know why new lines would leak at the transmission? Can I apply rtv or some other sealant to stop the slow drip of trans fluid? I'd really appreciate some input.
    Otherwise, would replacing the fittings be the next step? Or returning the new lines I installed?
  4. #24 Re: Stalling and Banging into Gear After TC Lockup
    GTP Level Member
    Aug 2012
    st louis park, MN
    I replaced the fittings with some from Napa and it appears the leaks are now resolved. It looks like there are small rubber o-rings inside the fittings. Given they are almost 10 years old, they probably just couldn't make a nice seal after the old lined were replaced.
    Hopefully this can help someone in the future.
  1. Light banging noise
    By Dadillac in forum General Grand Prix Discussion
    Last Post: 01-24-2014, 11:24 PM
  2. No 4th gear/ overdrive/ lockup
    By Prometheus in forum Introductions/Noob Questions
    Last Post: 06-26-2013, 07:18 AM
  3. Banging into gear from a stop, and a whine
    By 02NavyBlue in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2013, 11:42 AM
  4. No codes, slipping and banging
    By Momof2 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-01-2012, 07:22 PM
  5. wth is this banging noise???
    By spikedphilly in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2011, 11:20 PM
