Thread: Part throttle KR... How bad is it... really??
Results 1 to 20 of 24
  1. #1 Part throttle KR... How bad is it... really??
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    I believe these GTPs have part throttle KR from the factory (often seen on 4th gear in the highway, during part throttle cruise, when the engine is loaded and right around the vacuum/boost crossover point). I remember when I was logging with HPT one day on a pump gas build I did, I would see while driving in 4th gear 10* of KR at times when the engine was under load. This KR would be non-existent though when doing WOT pulls and heavy acceleration, etc.
    I have since tuned out the part throttle KR via transmission table setting changes (modifying the TCC tables, adjusting the downshift tables, etc.)
    My question is, how bad is that part throttle KR for these motors?? If they are so prone to it from the factory, and MANY people who go throw on a downpipe and a smaller pulley likely have a TON of it, does it really damage the motor in ways that other KR does? (Like WOT KR under much higher boost pressure and cylinder pressures??
    The responses to this may get interesting haha... But if folks have experience and think it is fine to have some part throttle KR in 4th, I may not modify my transmission tables any further and just allow a few degrees of KR from time to time. Having very little amounts of TCC (allowing a lot of slip) and downshifting from 4-3 all the time is not ideal in my opinion
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: Part throttle KR... How bad is it... really??
    take the sc belt off see if its still there. kr is kr. i suppose it could still chip a piston.
    have you touched your cruise timing? like raise it because of the corn? if so lower it closer to stock, or stock will also work.
  3. #3 Re: Part throttle KR... How bad is it... really??
    Mar 2014
    Cincinnati, OH
    timing tables are stock. I have experimented with them in the past but decided to keep them stock for this E85 setup.
    2002 GTP sedan:
  4. #4 Re: Part throttle KR... How bad is it... really??
    i dont see injectors in your sig's mod list. upgrade them yet? you need like 60's 42's wont cut it. stock wont make the show either.
  5. #5 Re: Part throttle KR... How bad is it... really??
    May 2008
    Schuyler, NE
    It's not as bad as wot kr. Most likely it'll never hurt anything with no boost, or just a couple of psi. 10* is kind of excessive, but 1-2 will most likely never hurt anything. But I am also very surprised you get any kr on e85 at part throttle.
  6. #6 Re: Part throttle KR... How bad is it... really??
    Kemmerer, Wyoming
    I remember taking a scan when I was doing a fair amount of highway driving. the scan would show blips of kr at 70 mph just crusing down the highway at maybe 15% throttle. the blips were never higher than 2*. I asked about them and the response was not to worry about it.
    In your case, 10* does seem excessive, so maybe there is something vibrating that the knock sensors are picking up.
  7. #7 Re: Part throttle KR... How bad is it... really??
    May 2008
    Schuyler, NE
    What year is the car, model, and mods?
  8. #8 Re: Part throttle KR... How bad is it... really??
    from his sig
    2002 GTP sedan: 3" downpipe|PLOG|poly mts|160 T*|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|Caspers FP rewire|WP UD Pulley|3.1 MPS|HP-Tuners
  9. #9 Re: Part throttle KR... How bad is it... really??
    May 2008
    Schuyler, NE
    Ok. At 15% throttlemail when you see the blips of kr, what does your vac/boost gauge read? Or map sensor?
  10. #10 Re: Part throttle KR... How bad is it... really??
    Mar 2014
    Cincinnati, OH
    Updated my sig to show that I do in fact have 60# injectors installed (still plenty of head room/duty cycle left on E85 with my current build). 2002 GTP sedan. mods in sig are updated now.
    The KR usually occurs right around when the engine crosses over into boost in 4th gear on the highway (anywhere from -1psi, up to 1.5psi or so) before it downshifts from 4th to 3th gear, based on how I have the transmission shift tables setup. I usually only see 1-2* of KR at the condition described above, but it still seems weird. I could always make the 4-3 downshift happen at a bit lower throttle position to downshift before the engine crosses over from vacuum to boost, or I could modify my PE table to come on sooner so it starts adding additional fuel right at that crossover point. Just pondering options at this point, and if that couple degrees of KR is really worth worrying about since I am only at like 20-25% throttle position at those conditions.
    2002 GTP sedan:
  11. #11 Re: Part throttle KR... How bad is it... really??
    If it was my car, I wouldn't even care one bit.
    Own a few GEN 4 LS trucks and you'll see them knock even more under minor load in high gear sometimes, yes they don't have a blower but the knock does no harm.
  12. #12 Re: Part throttle KR... How bad is it... really??
    Mar 2014
    Cincinnati, OH
    Thats what I was thinking.. two of my previous GTPs had that knock in 4th much worse than this one (because I was newer to building/tuning on this platform and didn't even realize it for a long time). Neither of those motors ever had issues as long as I owned them
    2002 GTP sedan:
  13. #13 Re: Part throttle KR... How bad is it... really??
    May 2008
    Schuyler, NE
    It just baffles me that you are getting any kr with e85. What timing are you commanding when the kr occurs?
  14. #14 Re: Part throttle KR... How bad is it... really??
    Not sure why it baffles anyone.
    This doesn't have to be spark knock. Vibrations or struggling against the torque converter can easily create false knock and have that show up in a log. E85 isn't the god of fuel to rule over all knock retard events.
  15. #15 Re: Part throttle KR... How bad is it... really??
    May 2008
    Schuyler, NE
    First you claim it's false knock. Then you claim it's detonation/preignition.
  16. #16 Re: Part throttle KR... How bad is it... really??
    May 2008
    Schuyler, NE
    You should figure out what point you are arguing before posting.
  17. #17 Re: Part throttle KR... How bad is it... really??
    I don't understand your post, my point was pretty clear.
    Just because it's on E85 doesn't mean it can't knock but I guess that doesn't come through to you?
  18. #18 Re: Part throttle KR... How bad is it... really??
    I didn't "claim" anything. I simply said it can easily be false then later said included that wonderful word "ALL", meaning ANY knock related event.
    That means real knock, false knock, spark knock, burst knock.
    Stop nit picking everything and get real here.
  19. #19 Re: Part throttle KR... How bad is it... really??
    Never Never Land
    My car knocks as well in 4th locked up. Here in SD the speed limit is 80 and I too will see a degree or two of knock right as it crosses over into boost. Climbing hills I may see as high as 10*
  20. #20 Re: Part throttle KR... How bad is it... really??
    May 2008
    Schuyler, NE
    When I was working in SD, I pulled timing back quite a bit while driving through the hills. But that was on 87 octane. With e85, I could run as much timing as I wanted to.
  1. Serious KR at part throttle only
    By 97AutoXVette in forum PCM Tuning
    Last Post: 05-09-2016, 06:35 AM
  2. High kr at part throttle after going wot
    By DoubleBlown in forum PCM Tuning
    Last Post: 12-19-2012, 06:54 PM
  3. Hesitation at part throttle
    By 99FormulaM6r in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-03-2012, 08:27 PM
  4. vid shot of my car going part throttle boost
    By fst in forum Track Sessions and Kills
    Last Post: 09-08-2011, 10:51 AM
  5. part throttle kr
    By Sabrewings in forum PCM Tuning
    Last Post: 06-09-2008, 09:30 PM
