Thread: Car shuts off/ drops idle when coming to a stop
Results 1 to 12 of 12
  1. #1 Car shuts off/ drops idle when coming to a stop
    Sep 2014
    United States
    Im back again!
    So after i drive my car for about 15 minutes, sometimes when i come to a complete stop i will see my RPM's drop to about 500 the lights on the dash will dim a bit but then it will go back up to about 800 rpm. Also when i am going real slow and turn into a parking spot the car has just completely shut off. Same thing then i try to back into a spot when i shift from drive to reverse my lights will dim and the RPM's will drop.
    I have cheked the IAC and MAf both have been cleaned, i have also tried a different IAC and there was no change.
    I realized tonight that if im just sitting still can crank the wheel to either side the lights will dim and RPM's will drop. Could that be a battery issue? Am i drawing too much power from the battery and alternator for them to keep up. I am not running heat or AC when it happens. But i do have a few extra accessories wired in, like 3 gauges, 1 12' Sub, water pump for my FSIC and a dash cam.
    Any thoughts would be appreciated
    Thanks
    Dan
    02 Grand Prix GT Mods' Top Swapped Gen 3, Stage 2 IC, 3.0" MPS, 42# injectors, 1.8 Yella Terra roller rockers, Speed Daddy Headers, CAI, Self Tuned, 180 tstat, ram air hood, front/rear sway bars/and STB's AL 104's, 12' Dual Piston Break kit
  2. #2 Re: Car shuts off/ drops idle when coming to a stop
    St. Louis
    What year GP? Dirty TB comes to mind. And when sitting still and turning the wheel it will put a strain on everything since you are at idle and are inducing more friction due to the tires not spinning as they would be when parking/driving. That's normal.
  3. #3 Re: Car shuts off/ drops idle when coming to a stop
    Sep 2014
    United States
    Year/mods are in the sig. Its an 02. The TB was cleaned about 5k miles ago i can take a look at it though.
  4. #4 Re: Car shuts off/ drops idle when coming to a stop
    Aug 2016
    CT/RI Border
    How old are your Cats? Plugged cat could do some of this.
    Sent from my ASUS_Z00TD using Tapatalk
  5. #5 Re: Car shuts off/ drops idle when coming to a stop
    Sep 2014
    United States
    It does not have a cat installed right now.
  6. #6 Re: Car shuts off/ drops idle when coming to a stop
    Aug 2016
    CT/RI Border
    Running with check engine light on or do you have the o2 sensor tuned out? Apologies if cat delete is in sig can't see on tapatalk.
  7. #7 Re: Car shuts off/ drops idle when coming to a stop
    Sep 2014
    United States
    Actually the check engine light is not on and i do not have the rear o2 sensor tuned out.
  8. #8 Re: Car shuts off/ drops idle when coming to a stop
    01 up you need the cat test killed with the rear o2 and cat delete or it can over fuel as its running the dumb test over and over.
  9. #9 Re: Car shuts off/ drops idle when coming to a stop
    Sep 2014
    United States
    Thanks for the info Scotty, that is something i was not aware of. I just corrected that in my tune.
    Now any other ideas on why the car will shut off randomly. Also ill add that on about 3 occasions in the past year i will start up the car and it will die instantly, it seems to be idleing too low. I can keep it running if i keep it reved up to 800rpm or above but it is not able to keep it there by itself. Then later that day it starts up an runs fine.
  10. #10 Re: Car shuts off/ drops idle when coming to a stop
    Aug 2016
    CT/RI Border
    Almost sounds like a head/intake gasket issue except for the running fine later. When was the last time full tune up/ basic replaceables were done? I'm not a fan of throwing parts at a problem until it goes away but if it's around time for plugs/wires/filters/egr I tend to start there.
    What output do you get from battery with car running? Same with car off. Did you have issues before installing the sub?
  11. #11 Re: Car shuts off/ drops idle when coming to a stop
    Sep 2014
    United States
    All gaskets were redone 2 years ago when i did the top swap.(about 15k miles) I have had the sub in the car for about 6 years. EGR has been deleted, cleaned my air intake filter about 6 months ago, spark plugs were changed less then 1k miles ago. Looksl like im getting 12.7v when the car is off and 14.2v when the car is running.
  12. #12 Re: Car shuts off/ drops idle when coming to a stop
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
    I have the same issue, except my car is an 04 Comp G, Batterry Voltage drops between 11.5ish and 13.5ish when this pulsing is happening with the RPM drop and low voltage battery light "pings", but has never stalled on me. I do have a voltage booster on it (for warmer heated seats and faster defroster) but it has done it even with it not installed.
  1. rpm drops when coming to a stop
    By bocou92 in forum Engine
    Last Post: 08-28-2014, 08:58 AM
  2. Trouble downshifting when coming to a stop.
    By wytmyk420 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-31-2011, 05:04 AM
  3. Fixed Idle problem Now the rpm drops and brakes pull help
    By PTGsDaytona500GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-25-2010, 07:14 AM
  4. Clunk when coming to stop and/or accelerating
    By trailshredder in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2010, 05:43 PM
  5. Car starts then as its about to Idle, car shuts off
    By fasterthenu2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 05:51 PM
