Thread: External coolant leak around tb/uim area?
Results 1 to 5 of 5
  1. #1 External coolant leak around tb/uim area?
    Sep 2015
    Lansing, Michigan
    I have a leak and it's around where the throttle body is. It runs around the uim gasket on that side but I can't seem to figure of its tb gasket or uim gasket. Last time I saw the leak, I found a loose stud on the tb to uim on the bottom so I tightened it but stripped the stud so I just switched the studs around and put the bad one on top.
    So I plan on going to jy and pulling some tb to uim studs and replacing the tb gasket.
    I just replaced the uim and lim gaskets a year ago and I did the uim with all new plenum, and dorman upgraded egr pipe for uim. What could it possible be? Coolant is only coming from the tb side. I have no coolant in the oil.
    Like I said the coolant leak is right around under the tb and I can't tell if it's uim, the uim gasket, or tb gasket. I dread pulling uim in this cold michigan weather
  2. #2 Re: External coolant leak around tb/uim area?
    if under the tb is wet its the tb gasket. pop it off have a look.
  3. #3 Re: External coolant leak around tb/uim area?
    Sep 2015
    Lansing, Michigan
    Alright. Is jy best place to get a set of the tb studs and nuts?
    I had this leak 2 weeks ago and the lower tb nut/stud was loose as could be so I took tb off and reseated gasket and put it all back together and now it's leaking in same exact spot. I just did the uim gaskets last year with the dorman upper uim kit with upgraded egr tube. Can these gaskets go bad that fast? Torqued too tight?
  4. #4 Re: External coolant leak around tb/uim area?
    you can get them at a hardware store. take a old one in with you, match it up. or swap to a bolt.
  5. #5 Re: External coolant leak around tb/uim area?
    Sep 2015
    Lansing, Michigan
    alright well i went to the jy and pulled off 3 studs and nuts. i replaced the tb gasket with a fel pro one and tightened everything snug. i didn't see any coolant inside the UIM. the old tb gasket is a orange or red dorman and appears to be a little pitted around the bottom of it where it seals the coolant ports. i compared the gasket sizes and the old dorman appears to be thinner around the bottom and the fel pro is thicker. i didn't see any warped plastic around the UIM meets TB area.
    can the gasket go bad? it's a year old. can it just flatten out if it's been tightened too much?
  1. Small coolant leak turned into a large coolant leak
    By DreamerGT in forum General Tech Discussion
    Last Post: 09-23-2016, 11:00 AM
  2. Oil leak near lower area of belt
    By twoleos617 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2014, 05:04 PM
  3. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. SF Bay Area assistance (LIM leak diagnosis)
    By Toxicologist in forum General Tech Discussion
    Last Post: 01-28-2010, 11:15 PM
