Thread: Clunk when coming to stop and/or accelerating
Results 1 to 5 of 5
  1. #1 Clunk when coming to stop and/or accelerating
    SE Level Member trailshredder's Avatar
    Feb 2009
    Central Ohio
    I have an annoying clunk when I start braking. Doesn't do it all the time, but most of the time. Also happens sometimes when I am starting to accelerate. Sounds and feels like it is coming from the front somewhere. I just replaced the upper motor mount bushings and the lower engine mount, thinking that was causing it but still does it. Any thoughts?
    02 Grand Prix GT, Silver with all options.
  2. #2 Re: Clunk when coming to stop and/or accelerating
    Nov 2009
    Grand haven
    strut mounts ????
  3. #3 Re: Clunk when coming to stop and/or accelerating
    Feb 2009
    Central Ohio
    Looked them over and gave everything a shake with my hand. Nothing really felt loose. Is it common? Upper or Lower?
  4. #4 Re: Clunk when coming to stop and/or accelerating
    Nov 2009
    Grand haven
    Either or you have to put a load on them. Open your hood and start the car with you FOOT on the brake put it into drive and give it some gas and see what moves. look at you engine throught the lil space between you hood and dash. see if it moves it foward and see if it moves in reverse. Brake tourque. also check your sway bar and sway bar links..
  5. #5 Re: Clunk when coming to stop and/or accelerating
    Donating Users timboku's Avatar
    Montgomery, IL
    Lower control arms. The bushing probably slipped out of the rear mount on it. Happens all the time. Also, check your sway bar to see if it is cracked and your sway bar links.
  1. bad vibration while accelerating help please!!!
    By 01RedfireGT in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2012, 08:54 PM
  2. 07 GP GXP Rear Clunk from stop to go
    By hodgietransam in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2010, 05:49 PM
  3. Troubleshooting HELP!!! Hesitation while accelerating
    By njs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-30-2010, 01:10 PM
  4. 02 GP Shakes upon accelerating
    By riddell87 in forum General Tech Discussion
    Last Post: 01-08-2010, 11:11 PM
  5. Sloshing sound while accelerating
    By Quicksilver_GP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 07:45 PM
