Thread: High pitched whine from engine bay.
Results 1 to 19 of 19
  1. #1 Re: High pitched whine from engine bay.
    HUDSON
    Removing the accessory drive belt, then start the engine and listen for the noise. While the belt is off check all the accessories
    for free movement, could be a bad bearing somewhere. Don't run the engine for too long without the belt.
  2. #2 Re: High pitched whine from engine bay.
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    Just check all of the accessory drive pulleys for freedom of movement? How long is acceptable to run it without the belt?
  1. high pitched whine when not on gas
    By yzboy85 in forum General Tech Discussion
    Last Post: 08-14-2014, 05:12 PM
  2. High Pitched Whine noise when I press on the gas
    By gentrymartin in forum General Tech Discussion
    Last Post: 07-12-2012, 01:50 PM
  3. High Pitched Horn Problem
    By Hippo Machine in forum General Tech Discussion
    Last Post: 11-26-2011, 10:24 AM
  4. High pitched whine
    By penguinknot in forum Brakes/Suspension/Chassis
    Last Post: 02-23-2011, 07:34 PM
  5. high pitched whine??
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2010, 03:37 PM
