Thread: High pitched whine from engine bay.
Results 1 to 19 of 19
  1. #1 High pitched whine from engine bay.
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    So my 2002 GTP has been having some electrical issues in terms of my subs grounding out and draining the battery, this has been resolved and I don't think it's related, but just putting it out there for full disclosure.
    I noticed a week ago my car was groaning when I was turning at times, so I figured the PS fluid was low. Grabbed some and topped it off a day or two later the car is now making a high pitched whining sound. Imagine electrical feedback from speakers sound. You can hear it at idle and the pitch gets higher and it gets louder with revs of the engine, turning the wheel back and forth doesn't affect it. The sound is coming from the back left of the motor bay, near where the power steering reservoir is. It is definitely louder when it's cold outside and the car is cold. Any ideas?
    p.s. I know it's the not the supercharger, I know what that one sounds like hahaha
  2. #2 Re: High pitched whine from engine bay.
    Jul 2016
    St. Louis
    Sounds like the Alternator to me. Especially since it gets louder as the engine revs. Take the belt off and spin the pulley to see if it spins freely or if it feels rough. You can also start the engine with the pulley off to see if the sound is gone.
  3. #3 Re: High pitched whine from engine bay.
    Feb 2009
    Roanoke, VA
    I'll give that a shot this afternoon, possibly the alternator going out?
  4. #4 Re: High pitched whine from engine bay.
    HUDSON
    Removing the accessory drive belt, then start the engine and listen for the noise. While the belt is off check all the accessories
    for free movement, could be a bad bearing somewhere. Don't run the engine for too long without the belt.
  5. #5 Re: High pitched whine from engine bay.
    Feb 2009
    Roanoke, VA
    Just check all of the accessory drive pulleys for freedom of movement? How long is acceptable to run it without the belt?
  6. #6 Re: High pitched whine from engine bay.
    Kemmerer, Wyoming
    When you say back left, do you mean driver side or passenger side? It could be the abs module going out
  7. #7 Re: High pitched whine from engine bay.
    Feb 2009
    Roanoke, VA
    You may be on to something here depending on where the ABS module is. It's the passenger side back near the alternator. I have been noticing my ABS activating at weird times, like turning hard left out of a parking lot, going down over the little ramp to the road and I can hear the sound of the ABS going.
  8. #8 Re: High pitched whine from engine bay.
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    If its already at operating temps, I wouldnt run it for more than a minute. Thats plenty of time to find whats loose. In fact, only run it long enough to see if the noise stops. If it does, shut the engine down and test each pulley. They should spin freely and should not have any lateral movement (shouldnt wiggle) They wont spin like a bicycle wheel or anything like that but the should spin easily without seizing up at all during a full rotation.
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  9. #9 Re: High pitched whine from engine bay.
    Kemmerer, Wyoming
    the abs module is on the driver side, but if you have a wheel bearing going out, it could be giving bad signals to the abs module, and the abs could be pulsating the brakes at strange times. abs module is right in front of the brake booster.
  10. #10 Re: High pitched whine from engine bay.
    Feb 2009
    Roanoke, VA
    Gotcha, I don't think I have any wheel bearing issues at the moment ha. I was tracking down a warbling sound from the tires so no more than a month ago I had all the wheels off checking the hubs only to find out one of my tires is dry rotting and has a major flat spot. So the ABS thing is still odd, albeit infrequent, but that's a whole other ball game for a different day haha
  11. #11 Re: High pitched whine from engine bay.
    Kemmerer, Wyoming
    the wheel speed sensor in the wheel bearing could be the only bad part on the bearing, or it could be a wire issue, both situations are entirely possible.
  12. #12 Re: High pitched whine from engine bay.
    Feb 2009
    Roanoke, VA
    Hmm I might have to check that sometime soon then. It's been pretty infrequent but unnerving when it happens because, well... you know, it's the brakes. Assuming it's just the wheel speed sensor which iirc is built into the hub, there's no easy way of narrowing down which is culprit without swapping and testing correct?
  13. #13 Re: High pitched whine from engine bay.
    Kemmerer, Wyoming
    sometimes you can see the wires are F***** up, if you have an abs scanner, you take the car for a drive and watch the left and right wheels, if one doesn't match the other, then it is a problem.
    the brakes will still work, I wouldn't sweat it too much.
  14. #14 Re: High pitched whine from engine bay.
    Feb 2009
    Roanoke, VA
    I'll have to dig in there and check the wiring on them at some point. I don't have an ABS Scanner unfortunately, just a bluetooth OBD2 reader which I'm fairly certain doesn't read the ABS stuff sadly.
  15. #15 Re: High pitched whine from engine bay.
    Jul 2016
    St. Louis
    My Alternator was charging fine when there was a noise coming from it. Long story short, bearings were worn out and I replaced it with a used one from local pick and pull $20.00. Problem solved.
  16. #16 Re: High pitched whine from engine bay.
    Feb 2009
    Roanoke, VA
    Oh yeah, I will definitely have to check my local pick and pull considering new ones are in the neighborhood of $130-$200.
  17. #17 Re: High pitched whine from engine bay.
    St. Louis
    My alt does the same thing. The old one did too and it finally quit charging one day. I slapped on a spare I had and it still does it. Sounds like junk and the pitch is ear piercing. Love to figure out if this alt is going bad too.
  18. #18 Re: High pitched whine from engine bay.
    Jul 2016
    St. Louis
    Quote Originally Posted by FordMan77 View Post
    Think you answered your question. If it's making noise, something inside is going bad. It will keep charging if it's just the bearings, but eventually it's going to fail completely.
  19. #19 Re: High pitched whine from engine bay.
    St. Louis
    I just found it strange that the spare that I swapped on made the exact same noise right off the bat. Guess I'll add a new alt. to the list of stuff to get.
  1. high pitched whine when not on gas
    By yzboy85 in forum General Tech Discussion
    Last Post: 08-14-2014, 05:12 PM
  2. High Pitched Whine noise when I press on the gas
    By gentrymartin in forum General Tech Discussion
    Last Post: 07-12-2012, 01:50 PM
  3. High Pitched Horn Problem
    By Hippo Machine in forum General Tech Discussion
    Last Post: 11-26-2011, 10:24 AM
  4. High pitched whine
    By penguinknot in forum Brakes/Suspension/Chassis
    Last Post: 02-23-2011, 07:34 PM
  5. high pitched whine??
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2010, 03:37 PM
