Has anyone else use the cloyes chain and gears? The cam position magnet was pretty much too big because the cam sprocket wasn't wide enough and is ON the gear that runs the balance shaft leaving just the smallest gap between the two sprockets on one side after it was torqued down. One side is clearly on the balance gear drive sprocket and the side with the magnet you can just barely see light through it.
