Thread: Raising engine from below
Results 1 to 20 of 40
  1. #1 Raising engine from below
    Sep 2015
    IL
    Need to change oil pan gasket, its my understanding that you need to raise the engine enough to unbolt and remove the u-bracket to get clearance to remove the pan. I don't have a cherry picker so my plan is to lift the engine from below. I've done this before when I changed my lower motor mount, just placed a 2x8 across the tranny/oil pans and that worked well. This time though obviously I can't span the board across both of them, will it be a problem lifting the engine by the trans pan? I'm not concerned about it holding the weight, but the fact that if I lift here this really isn't lifting off the center off gravity so I'm afraid it will only lift one side of the engine up (not the side I need). The write-ups I read describe people lifting the engine up from only the tranny pan but I'm not sure. Don't wanna get started on this, crawl under there only to find I can't raise it high enough by doing that.
  2. #2 Re: Raising engine from below
    You could hang the engine and drop the sub frame and have room to spare for the whole job.
  3. #3 Re: Raising engine from below
    Omaha, NE
    You can lift the engine slightly, remove the u bracket from the engine and then get to the oil pan bolts. It's not a lot of fun with the steel pan. Which is why I swapped to the alumunimununununununum one.
  4. #4 Re: Raising engine from below
    Jan 2014
    AR
  5. #5 Re: Raising engine from below
    Sep 2015
    IL
    So in terms of replacing the gasket, I've read using RTV "on both sides" is a good idea. What exactly does "both sides" mean? A bead all the way around on top the in-laid rubber gasket?
  6. #6 Re: Raising engine from below
    Omaha, NE
    Both sides would be both sides of the gasket. Follow the red line with a thin bead of RTV, then trace around the bolt holes. Don't overdo it though, you don't want RTV getting in the oil.
    Sent from my iPhone using Tapatalk Pro
  7. #7 Re: Raising engine from below
    easiest way is to rtv the block and the pan. run a bead around each, then with your finger smooth it out so its like a mm thick or so.
    put thread sealant on the pan bolts too. clean them of any oil too.
    and make sure you take the oil level sensor out the pan before you take the pan off or you will break it. its the last thing to go back on too. or you will break it.
  8. #8 Re: Raising engine from below
    Sep 2015
    IL
    got it, thanks
  9. #9 Re: Raising engine from below
    Sep 2015
    IL
    Just to double check this should be done even for steel pans with gasket correct?
  10. #10 Re: Raising engine from below
    Omaha, NE
    Yes.
  11. #11 Re: Raising engine from below
    the steel pan will leak most of the time if you dont rtv it.
    i also suspect the bolts of leaking too, why i suggest thread sealant on them.
  12. #12 Re: Raising engine from below
    Sep 2015
    IL
    Man this job sucks lol. Halfway thru got the pan off, I have a feel its going to be a pain to re-start the five bolts on the motor mount, mostly the one in the back on top near the transmission. I'm guessing you just have to stick the bolt in the wrench and slide it up there and start it that way, no way my hand will fit.
  13. #13 Re: Raising engine from below
    engine to tranny bracket is in the way i bet. keep at it.
  14. #14 Re: Raising engine from below
    Sep 2015
    IL
    Any tips on how to remove the old gasket, it's still on there pretty good and it's hard to pry around it. If I yank on it enough will it give?
  15. #15 Re: Raising engine from below
    yank on it, theres holes in it you can put your fingers in and pull down. then snake it around the oil pump screen and neck.
  16. #16 Re: Raising engine from below
    Topeka, KS
    Interesting. My new gasket was firmly attached to the block. I removed the Fbody pan and put a gp pan on. I didn't rtv between the pan and gasket. Just rtv on the gasket to block. It wasn't that way already.
  17. #17 Re: Raising engine from below
    its worth doing, takes nothing for the extra step. my engine had a new gasket installed before i got it, it was leaking, it was installed dry. the rear cover was also showing signs of leaking.
    all new engine gaskets and the pan rtv'ed and over a year now 100% leak free. nice and dry under there.
  18. #18 Re: Raising engine from below
    Sep 2015
    IL
    You know what really slows me down? 12 year old gaskets that are fused to the metal. The stupid little oil return tube gasket is impossible to get off all I have is a little gasket scraper. Should I soak it in something?
  19. #19 Re: Raising engine from below
    if its stuck to the tube, use sand paper on a block of wood. fine stuff 150 or finer is fine. then wash it with brake cleaner good. up the tube and any where and sand might end up from the paper.
  20. #20 Re: Raising engine from below
    Sep 2015
    IL
    What about the rest of the gasket stuck to the block where the return tube goes? I hesitate to use sand paper on that, there isn't much stuck to it. I got it all off the return tube itself. Would it really be a problem to just leave the little bit stuck to the block considering I'm going to be RTV'ing both the block and the pan?
  1. Raising Low-End Torque
    By 04gtpnoob in forum 04+ Specifics
    Last Post: 03-07-2016, 12:53 PM
  2. raising the ass in 03 gp
    By 03limitedgtp in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2015, 11:38 PM
  3. raising the rev limit
    By SgtMarshal in forum PCM Tuning
    Last Post: 03-02-2015, 05:37 PM
  4. BLACKxFLAGx Raising It UP! plus suspension woes....
    By blackflag in forum Members Rides
    Last Post: 10-11-2013, 11:00 AM
  5. raising offset on my wheels....yes or no?
    By twol8uluz in forum Tires & Wheels
    Last Post: 03-30-2012, 07:02 PM
