if its stuck to the tube, use sand paper on a block of wood. fine stuff 150 or finer is fine. then wash it with brake cleaner good. up the tube and any where and sand might end up from the paper.
What about the rest of the gasket stuck to the block where the return tube goes? I hesitate to use sand paper on that, there isn't much stuck to it. I got it all off the return tube itself. Would it really be a problem to just leave the little bit stuck to the block considering I'm going to be RTV'ing both the block and the pan?
