easiest way is to rtv the block and the pan. run a bead around each, then with your finger smooth it out so its like a mm thick or so.
put thread sealant on the pan bolts too. clean them of any oil too.
and make sure you take the oil level sensor out the pan before you take the pan off or you will break it. its the last thing to go back on too. or you will break it.
