tankiing the t stat housing off is not helping you in any way to change the temp sensor. but if you feel the need to take it off. once done with the temp sensor, fill the engine with new coolant via the hole for the t stat. and fill the rad. now you know its all full.
It's a real tight squeeze with the thermostat housing and hose. How do you suggest I do it then?
