Thread: Temperature gauge always on red . 260
Results 1 to 20 of 37
  1. #1 Temperature gauge always on red . 260
    Oct 2016
    Texas
    My temperature gauge rises fast after starting the engine when it's cold. And it always stays at 260(highest) when I'm driving. I have already replaced thermostat, temperature sensor, and bled the cooling system and still stays high. The engine doesn't seem to overheat though. Anybody can help me figure what's wrong?
  2. #2 Re: Temperature gauge always on red . 260
    Kemmerer, Wyoming
    I wonder if there is a blockage in the coolant system that isn't allowing the the coolant around the thermostat to circulate.
  3. #3 Re: Temperature gauge always on red . 260
    fans coming on? them temp sensors are known to be dead in the box new. its a two part sensor, one signal to the dash, the other to the fans. one or the other fails.
  4. #4 Re: Temperature gauge always on red . 260
    Oct 2014
    portland oregon
    No I think if he was driving around at 260 his car woulda cracked or blown something out by now. but idk what it would be
  5. #5 Re: Temperature gauge always on red . 260
    Oct 2016
    Texas
    Yes the fans turn on.
  6. #6 Re: Temperature gauge always on red . 260
    give that little harness a good looking over for cracks or missing insulation on the wires. if you see bare wire, the harness is the issue, it bakes in the heat from the exhaust.
    if the wires look ok, toss another sensor in there.
  7. #7 Re: Temperature gauge always on red . 260
    Kemmerer, Wyoming
    I've had bad luck with the aftermarket sensors before, now I only use the ac delco temp sensors. they are like 10 or 20 bucks on amazon.
  8. #8 Re: Temperature gauge always on red . 260
    Oct 2016
    Texas
    Ok I will do that
  9. #9 Re: Temperature gauge always on red . 260
    hangover park IL
    the later cars only use a 2 wire. early cars with the 3 wire have the older gauge clusters that have a dedicated temp sensor input VS over the Serial/CAN bus units of ~00+
    ive seen plenty of "repaired" clusters too...its possible the needle was incorrectly installed/stepper has a position error, use a scan tool to check for Instrument Panel Cluster computer codes
    ~James~ Psychotic Gearhead
  10. #10 Re: Temperature gauge always on red . 260
    Oct 2016
    Texas
    Are those the same ones from a gm dealership?
  11. #11 Re: Temperature gauge always on red . 260
    Oct 2016
    Texas
    My is a 2002 gtp. The gauge used to work
  12. #12 Re: Temperature gauge always on red . 260
    Oct 2016
    Texas
    Just a thought. I have a 16 psi radiator cap. Would that be making the problem since the stock one is 15 psi?
  13. #13 Re: Temperature gauge always on red . 260
    Kemmerer, Wyoming
    Quote Originally Posted by Diegozr1 View Post
    Should be fine
  14. #14 Re: Temperature gauge always on red . 260
    Oct 2016
    Texas
    The wires look ok. It doesn't have insulation though.
  15. #15 Re: Temperature gauge always on red . 260
    insulation is what the wires are wrapped in. at the end of the plug where the wires go in is a common point to break.
  16. #16 Re: Temperature gauge always on red . 260
    Oct 2016
    Texas
    The ends are still intact. Would a leak in the radiator cause the gauge to be high?
  17. #17 Re: Temperature gauge always on red . 260
    if you have a leak fix it. if the coolant is super low, sure it can run hot.
  18. #18 Re: Temperature gauge always on red . 260
    Oct 2016
    Texas
    I had a small hairline Crack on the plastic tank and I put some jb weld. And it fixed it. I'm going to buy a new radiator just haven't had money. The radiator is always full. I already went to a gm dealership and order a sensor from them. They should have it by tomorrow morning. So hopefully that one fixes the gauge.
  19. #19 Re: Temperature gauge always on red . 260
    Oct 2016
    Texas
    So if the radiator is full and fans come on. That means it's not running hot? Just the bad sensor is giving a bad reading?
  20. #20 Re: Temperature gauge always on red . 260
    most of the time your fine, open the bleeder a top the t stat housing car running and hot and make sure its bled properly of air, if you open it and coolant streams out your good to go.
    if it just spits bubbles leave it open till a stream comes out.
  1. temperature not registering on gauge
    By 01buickregalsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2015, 10:09 PM
  2. Temperature gauge reading hot!
    By gloryabides in forum General Grand Prix Discussion
    Last Post: 01-10-2013, 10:31 PM
  3. Help With Temperature Gauge issue!
    By gcschi22 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-02-2011, 10:55 AM
  4. Temperature gauge fluctuates
    By wagatlng in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-07-2010, 01:05 PM
  5. Is the temperature gauge accurate?
    By Summit670 in forum General Tech Discussion
    Last Post: 12-22-2008, 12:07 AM
