most of the time your fine, open the bleeder a top the t stat housing car running and hot and make sure its bled properly of air, if you open it and coolant streams out your good to go.
if it just spits bubbles leave it open till a stream comes out.
I did that the other day. And the first time it was spitting bubbles and second just a stream. Well i already picked up the oem temperature sensor and I will install it tomorrow morning. What is the proper way of bleeding the cooling system because I'm removing the thermostat housing to reach it better. So I will be topping it off again for the loss of any antifreeze.
