Thread: Raising engine from below
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: Raising engine from below
    the tube need to be sealed tight or it will suck air not oil up. you need to get that cleaned off inside there good. some kind of scrapper is needed.
    if you mean the block where the pan meets use a razor blade to scrape off any stuck on crap.
  2. #22 Re: Raising engine from below
    Sep 2015
    IL
    I had no problem getting the old gasket/rtv off where the block/pan meet. I'm talking about the little return tube gasket, half of it ripped off onto the actual tube (which I was able to sand off), the other half is stuck to the block. Can I just sand that too? My razor blade scraper does absolutely nothing to it, just passes right over.
  3. #23 Re: Raising engine from below
    Topeka, KS
    Oh the oil pickup gasket I think is what he's talking 'bout. Just use a gasket scraper.
  4. #24 Re: Raising engine from below
    got a sharp chisel? use that, or a screw driver or pick to pick it off there. or even a razor locked in some vice grips or pliers of some sort works.
  5. #25 Re: Raising engine from below
    Sep 2015
    IL
    Tried that, the gasket material hardened and caked on there after 12 years just doesn't flake away using the scraper. I'll try a screwdriver and lightly hitting it with a mallet. I'm just scared about nicking the block. Gonna feel good to be done after this one LOL. I had to do lim/vc gaskets back in february now this. I swear if this car needs another major repair in the next 6-12 months I'm taking it somewhere.
  6. #26 Re: Raising engine from below
    chisel will pop it right off, with a palm hit to its handle. wood chisel will do the trick.
  7. #27 Re: Raising engine from below
    Topeka, KS
    Eh, if you are tearing it down this far by yourself you can handle other things. You got this!!!
  8. #28 Re: Raising engine from below
    Sep 2015
    IL
    Nope, I don't go this. Last time I try doing something this big myself. Had the block and pan all cleaned off and RTV'd, put the gasket on, went to stick on the return tube and gasket and my sweaty hands dropped it. Figured the return tube gasket would just fall on the floor, but NOPE. Its lost in the abyss I mean I have no idea where this thing went.
  9. #29 Re: Raising engine from below
    Sep 2015
    IL
    Does anyone know where i can buy the return tube gasket by itself? Rockauto only has it with the oil pan gasket.
  10. #30 Re: Raising engine from below
    is it dark out? wait till morning if it is, you'll find it
  11. #31 Re: Raising engine from below
    Topeka, KS
    How fast do you need it? I have like 2-3 for the pickup tube.
  12. #32 Re: Raising engine from below
    Sep 2015
    IL
    Its in my garage, turned all my lights on and everything. I can't believe I lost this. The place where the tube goes is just open space right above the garage floor. There's no crevice it could have fallen into or anything. I did have the oil pan gasket on, so I thought it fell into that. Took that off. Nope.
  13. #33 Re: Raising engine from below
    Sep 2015
    IL
    Quote Originally Posted by rynoman03 View Post
    ASAP, we're talking about this little guy right?
    http://www.carid.com/images/melling/...mages/256s.jpg
  14. #34 Re: Raising engine from below
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    make one from a cereal box, coat it in thin rtv with your fingers.
  15. #35 Re: Raising engine from below
    Sep 2015
    IL
    Now i have to scrape off all the friggin RTV that is gonna cure. I also broke the flywheel cover when i raged, anyone know where I can get that too lol.
  16. #36 Re: Raising engine from below
    Topeka, KS
    Quote Originally Posted by 310toumad View Post
    Yup. Well mine are at my buddies house 1.5 hr away. It's Reptile on here. If you pm him i'm sure he could send you one. But you are better off just buying one local.
  17. #37 Re: Raising engine from below
    Topeka, KS
    moradpartscompany.com
  18. #38 Re: Raising engine from below
    why would you put the gasket on then the oil tube? oil tube first, then finagle the gasket over the oil tube.
  19. #39 Re: Raising engine from below
    Sep 2015
    IL
    I read that its easier to remove the gasket by taking off the oil tube first, and then replacing it first before putting the gasket back on thereby eliminating the need to shimmy the gasket around the tube to slide it on.
  20. #40 Re: Raising engine from below
    cant see it being a issue. its why theres a hole so big for it.
  1. Raising Low-End Torque
    By 04gtpnoob in forum 04+ Specifics
    Last Post: 03-07-2016, 12:53 PM
  2. raising the ass in 03 gp
    By 03limitedgtp in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2015, 11:38 PM
  3. raising the rev limit
    By SgtMarshal in forum PCM Tuning
    Last Post: 03-02-2015, 05:37 PM
  4. BLACKxFLAGx Raising It UP! plus suspension woes....
    By blackflag in forum Members Rides
    Last Post: 10-11-2013, 11:00 AM
  5. raising offset on my wheels....yes or no?
    By twol8uluz in forum Tires & Wheels
    Last Post: 03-30-2012, 07:02 PM
