Thread: Easiest way to remove rear strut?
Results 1 to 5 of 5
  1. #1 Easiest way to remove rear strut?
    Sep 2015
    Lansing, Michigan
  2. #2 Re: Easiest way to remove rear strut?
    Remove the sway link bolt to the strut, remove the 2 bolts on the knuckle and then the 3 holding the strut inside the trunk.
    That's about as easy as it gets.
  3. #3 Re: Easiest way to remove rear strut?
    Antioch, IL
    *use hammer to knock out the 2 lower bolts, they are splined and not made to turn (bolts not the nuts)
    2009 Challenger SRT8
    Expert at being gay.
  4. #4 Re: Easiest way to remove rear strut?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    step zero: spray the crap out of all fasteners with PB blaster a couple days before hand
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  5. #5 Re: Easiest way to remove rear strut?
    Nov 2011
    NY
    Actually... Is that a trick question? Because the easiest way........... Is to let someone else do it!
    hahaha, I had to...
  1. How To Remove '04+ Rear Deck (speakers)
    By SlowNA06 in forum How To Write-Ups/Tech Tips
    Last Post: 10-08-2011, 07:28 PM
  2. remove rear bumper
    By dgjks6 in forum General Tech Discussion
    Last Post: 10-31-2010, 08:46 AM
  3. trying to remove rear speaker grills...
    By larson88 in forum General Tech Discussion
    Last Post: 04-21-2010, 08:44 AM
  4. please help! how to remove rear speakers to put new ones!
    By gpgtp99 in forum Audio, Security & Visual Electronics
    Last Post: 12-13-2009, 05:18 PM
  5. how to remove rear speakers ??
    By bayareagtp in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2008, 10:52 AM
