Thread: Rear end noise?
Results 1 to 20 of 29
  1. #1 Rear end noise?
    Sep 2015
    Lansing, Michigan
    02 gp gt 200k miles
    Car has a noise coming from the passenger side rear. Almost sounds like it's inside the trunk. Every time I hit a bump it makes a noise. It almost sounds like it's a hollow clunk. It's not a sharp popping type clunk like a front broken stabilizer bar makes. Car has been making this noise ever since I bought it a year ago. It's not a very loud noise but it's enough to wonder what's causing it. I never picked up on the sound until a month after I bought the car.
    I checked rear seats, trunk, spare tire area. Strut towers look normal and there's no rust on them. Car drives straight down the road. No wobbles. The springs do sag a bit in the rear.
    I'm aiming towards a possible bad strut mount. Are these hard to change out? I have all the tools except a spring compressor which I can probably rent. Autozone sells the mounts for $22 each.
  2. #2 Re: Rear end noise?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    rear sway end links?
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: Rear end noise?
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Quote Originally Posted by WarStryker13 View Post
    I second this. 99% guarantee
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  4. #4 Re: Rear end noise?
    Antioch, IL
    end links ftw
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: Rear end noise?
    Sep 2015
    Lansing, Michigan
    any way to check them? do I need to jack up the entire back end at once? or can I just do one wheel at a time?
    where's the best place to jack it up at? I live in the rust belt so my pinch welds are a little weak.
  6. #6 Re: Rear end noise?
    Enfield, CT
    Quote Originally Posted by tom5170 View Post
    crawl under car, grab rear sway bar as hard as you can and push up on bar to reduce load on end links and as you are pushing up the bar, grab end-links and wiggle them to see if there is play.
  7. #7 Re: Rear end noise?
    SE Level Member jmartell's Avatar
    Jan 2016
    Centre Wellington, Ontario
    Quote Originally Posted by HighOctaneRacing View Post
    So with the car on the ground I reached around the wheel and grabbed the end link and it started moving around up and down and making a clunking noise. So looks like that's my culprit. Are junkyard ones any good? I gotta go there tomorrow to get some parts for my mom's car.
    it would appear hes got it sorted.....
    Lack of planning on your part does NOT constitute an emergency on my part.
    Drive more, worry less
  8. #8 Re: Rear end noise?
    Oct 2014
    Frederick, MD
    Best way is just to climb under the back and try to wiggle them with your hands. If they move, they're bad.
    Try a block of wood with a groove that the pinch welds fit into, at least 12 inches long to spread the load...
  9. #9 Re: Rear end noise?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Or a rusted out strut tower.
    Never lift up by the pinch welds. lift on the molded frame rail. (runs next to the fuel filter)
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  10. #10 Re: Rear end noise?
    Oct 2014
    Frederick, MD
    Quote Originally Posted by rickisrad View Post
    Uhm... What frame rail? We drive a unibody design car. Lol
    And I'm pretty sure that pinch weld, where the factory marks the lift point on the side skirt, is the factory designed strongest point to lift from.
  11. #11 Re: Rear end noise?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    if you lift by the pinch weld in any rust state your going to collapse the rocker. ill attach pics to show what i mean
  12. #12 Re: Rear end noise?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    exhaust banging underneath? look on the passenger side where it bends around the gas tank. if you have a bent hangar or bad rubber mount it can rub / bang into the frame.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  13. #13 Re: Rear end noise?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Lift here. Not sure what to call it so I called it a molded frame rail.
    Not Here!! This is the result of Firestone lifting at the pinch weld.
  14. #14 Re: Rear end noise?
    Oct 2014
    Frederick, MD
    That's some pretty nasty rot you got going there...but I see what you're saying.
    In the case of rust like that, I would not lift by the pinch weld. But a block of wood will prevent you from collapsing that moulded rail looking piece, like I've seen happen on completely rust free cars. I.E. mine. Lol
    I can upload pics later, but mine are almost minty compared to that, and I'll show where my moulded rail started to collapse because of previous idiot owners.
  15. #15 Re: Rear end noise?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Yeah they use a ton of salt here!! It was made in 2002 and from car fax says its been here all its life. I'm the third owner, it was a little too late once I got it 6 years ago. and yes I definitely use a block of wood to disperse the pressure.
  16. #16 Re: Rear end noise?
    Oct 2014
    Frederick, MD
    The car fax on mine says it was in Maine for 5 years, then shipped overseas to Germany for 4, then I got it and shipped it back overseas to AK. The trip back from Germany took almost 4 months, 3 of those months was on the boat, ocean spray was so bad it coated the interior completely with a layer of salt over everything... But no rot.
    Those moulded rails look factory new still on mine, same with the strut towers. The only things with anything deeper than surface rust is stuff like the old control arms and the battery tray, things that can be replaced....
    I've been saying mine's a weird one since the start. Lol
  17. #17 Re: Rear end noise?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    That's great you avoided the rot!! Unfortunately mine is about the norm here, unless it was really taken care of from the start. This one is way worse than my previous Prixs The previous owners must have never washed the underside.
  18. #18 Re: Rear end noise?
    Antioch, IL
    put the jack in the middle of the rear subframe and lift, not that hard. war likes to talk so dismiss her.
  19. #19 Re: Rear end noise?
    Sep 2015
    Lansing, Michigan
    Are the threaded end parts of the end links where the nuts go supposed to rotate? The passenger side rear where the noise is coming from rotates. I took it off and found this out. Maybe it's part of the design lol but I thought those bolt/threaded looking things are supposed to be solid inside the rubber and not move
  20. #20 Re: Rear end noise?
    Antioch, IL
    new ones wont rotate just replace them
  1. Noise from rear 04 GT GP
    By GOGOPONTIAC in forum General Grand Prix Discussion
    Last Post: 09-23-2015, 11:27 PM
  2. Popping noise in rear?? HELP
    By 3R1CD4V15 in forum Brakes/Suspension/Chassis
    Last Post: 01-18-2012, 01:56 PM
  3. Rear end noise
    By reddog in forum Brakes/Suspension/Chassis
    Last Post: 03-05-2011, 07:12 PM
  4. Humming noise from rear of car
    By jokyfo in forum Tires & Wheels
    Last Post: 06-04-2010, 01:36 PM
  5. Rear noise
    By musiknjoyr in forum Brakes/Suspension/Chassis
    Last Post: 01-20-2010, 03:09 PM
