Quote Originally Posted by tom5170 View Post
Go to the jy and grab some coil packs and injectors. I did that last summer and paid $5. Came with a 30 day warranty
Ok so a little update, I changed the Ignition Control Module and all 3 coil packs. Changed the entire ignition harness including multi switch and new ignition switch... problem persists.... However on my old harness I spliced in a toggle switch and for the life of me I can't rember what wires I put it on, it allowed the car to run if I started it on either without shutting off... Sense I changed the Harness the problem is back which is pointing me straight to the KeyPass 3 system failing, dealer wants over 900 to replace the entire security system, I have already put a grand in parts in this car =( I am trying to figure out how to bypass the security system either with a toggle switch or a resistor, but every video I have seen on this bypass says there is a small yellow wire coming from the ignition and should goto pin b6 on the BCM plugin... now my 2003 GTP doesn't have any small yellow wire coming from the ignition, has a huge yellow (starter wire) I have been messing with a multi meter and can't for the life of me figure out which two wires will show the resistor resitance when the key is turned to on.... help please
