Thread: Can I rust proof the trail arm brackets/knuckles?
Results 1 to 19 of 19
  1. #1 Can I rust proof the trail arm brackets/knuckles?
    Sep 2015
    Lansing, Michigan
    02 gp gt. I live in Michigan (SALT) 200k on the car.
    The body on this thing is damn near immaculate body wise, or so I thought.
    Upon crawling around on the ground looking around at the rear suspension, I noticed I have some pretty intense surface rust around the trailing arm brackets and knuckles. It's enough rust that turned the whole knuckle brown and it appears that there's old black paint or flakes/remnants of it, most likely the factory coating.
    There's a little surface rust on some parts of the undercarriage, but those areas seem the worst.
    So is there a way I can fix this rust or at least slow it down? Can I use a wire wheel and get all the rust off of the knuckle/mount area and maybe spray something on the area? Some kind of coating or rust stopper?
  2. #2 Re: Can I rust proof the trail arm brackets/knuckles?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    New trailing arm brackets are 10 ish bucks a piece from RockAuto, before putting them on rattle can some rubberized undercoating or truck bed liner kind of stuff...
    Other than new, it'll be a pain to get all of the rust off the old brackets, and they'll be rusting again in a few years...
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: Can I rust proof the trail arm brackets/knuckles?
    Omaha, NE
    ZZP sells full chromemoly tubular trailing arms for $120. I would buy a set of those and put a few extra coats of paint on them and never worry about it again.
  4. #4 Re: Can I rust proof the trail arm brackets/knuckles?
    Oct 2014
    Frederick, MD
    It's not the trailing arms themselves, it's the brackets that hold them to the body that we're talking about.
  5. #5 Re: Can I rust proof the trail arm brackets/knuckles?
    Omaha, NE
    My coffee hasn't kicked in yet.
    Either way, grab some new ones and slap 3-5 coats of paint on 'em. They should last a long time that way.
  6. #6 Re: Can I rust proof the trail arm brackets/knuckles?
    Aug 2016
    MN
    I've used Eastwoods rust converter/encapsulator products with a rubberized undercoating applied as a top coat with very good results and I live in MN.
    I would still buy the new mounts since they are powder coated (or the ones I got from the dealer years ago were) and treat the body underneath them.
    1998 Grand Prix GTP aka The Family Sedan
    CAI, 1.8 rockers, U-bend delete, 3.4 pulley, tuned by me
    1999 Turbo Grand Prix
    L36 turbo build in progress
  7. #7 Re: Can I rust proof the trail arm brackets/knuckles?
    Sep 2015
    Lansing, Michigan
    Would rustoleum work? I have a can of it laying around.
  8. #8 Re: Can I rust proof the trail arm brackets/knuckles?
    Aug 2016
    MN
    Quote Originally Posted by tom5170 View Post
    Im assuming you are talking about just the paint. It's a good top coat but in my experience it will not slow or stop untreated rust. It will be peeling within a year or two.
  9. #9 Re: Can I rust proof the trail arm brackets/knuckles?
    Sep 2015
    Lansing, Michigan
    Yeah as a top coat. Can I just use Eastwoods rust converter? And then a top coat like rustoleum or a rubberized coating?
    Can I get this stuff at auto zone?
  10. #10 Re: Can I rust proof the trail arm brackets/knuckles?
    Oct 2014
    Frederick, MD
    I don't know about the Eastwoods, but the rubberized coating/underbody paint you can easily find at autozone.
  11. #11 Re: Can I rust proof the trail arm brackets/knuckles?
    Sep 2015
    Lansing, Michigan
    How easy are the bracket bolts supposed to loosen? I just loosened all the bracket bolts while car was on the ground with ease. I tightened them back up snug and they didn't feel stripped. Just wondering because there's rust there I thought it would be a pain in the ass or they would snap off or strip.
  12. #12 Re: Can I rust proof the trail arm brackets/knuckles?
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    also, check the prices on POR-15 products. I have used this on my battery tray and other parts on my '02 GP (which I have owned since '04) and there is no rust whatsoever. I now wish that I would have dipped the entire car into this stuff back in 2004. What ever you put it on, it will never rust again
  13. #13 Re: Can I rust proof the trail arm brackets/knuckles?
    Aug 2016
    MN
    When treating rust I usually overkill. Wire wheel as best you can first. Then rust converter, then encapsulator over that, then rubberized undercoating and a top coat (rustoleum) if desired. I probably wouldn't spend the money on Eastwoods rubberized undercoating, any brand should suffice. I saw that rustoleum makes some. It's probably pretty good although I haven't tried it yet.
    POR 15 is more expensive but is supposed to be amazing. Although I have heard that it will not bond well to non rusty metal. I have personally never used it.
    The bolts are decent size and if you got them turning you are likely good to go. The trailing arm bolts themselves are another story however. I ended up grinding them off as the bolt was seized in the bushing. That's how I ended up with gmpp trailing arms as they were cheaper than stockers.
  14. #14 Re: Can I rust proof the trail arm brackets/knuckles?
    Oct 2014
    Frederick, MD
    I ended up pulling the entire sleeve out of the bushing in my stock trailing arm... Big socket and a hammer solved that problem. Lol
    I use a 4 1/2" angle grinder with a wire wheel for bolts like that, they usually end up looking almost brand new, and the threads are more often than not just clogged with rust, the actual threads themselves are still in good shape, just need cleaned up.
  15. #15 Re: Can I rust proof the trail arm brackets/knuckles?
    Antioch, IL
    sandblast +epoxy primer + moisture cured urethane paint = supreme
    2009 Challenger SRT8
    Expert at being gay.
  16. #16 Re: Can I rust proof the trail arm brackets/knuckles?
    Oct 2014
    Frederick, MD
    Sandblaster tank = ~$200
    New brackets =$20
    No need for blasting.
  17. #17 Re: Can I rust proof the trail arm brackets/knuckles?
    Antioch, IL
    Gravity feed/siphon $20
    sand 50lb under $5
    Not gonna do it right, then who gives a **** what you do? Half assed is half assed is half assed
  18. #18 Re: Can I rust proof the trail arm brackets/knuckles?
    Oct 2014
    Frederick, MD
    Why sand blast new parts?
    especially when they're cheap? Plus I'm pretty sure epoxy primer will stick just fine to factory powdercoat, or whatever is on the new ones.
    MCU would be best though, I'll give you that. Never worry about rust again after that.
  19. #19 Re: Can I rust proof the trail arm brackets/knuckles?
    Jan 2014
    AR
    Good entertainment here. I've never heard it called MCU. Eastwood stuff works great, the encapsulator is crazy good IMO and the converter ain't bad. For underneath a FWD GP I can't imagine using anything fancier than engine spray paint. The key is prep of course, but also using an actual topcoat paint and plenty of it. You gotta put enough coats! Skip anything rubberized unless you need it for chip protection or sound deadening. It is porous. Paint is not.
  1. It's out... Proof.
    By 02 WS6 TA in forum Other Vehicles
    Last Post: 05-20-2015, 09:25 AM
  2. Hello fellow Pontiyackers.New dewwwde Indian Trail, N.C.
    By Stage III in forum Introductions/Noob Questions
    Last Post: 01-07-2013, 08:11 AM
  3. bullet proof
    By nemesis in forum Visual/Body Modifications
    Last Post: 07-27-2009, 12:39 AM
  4. Water proof GenV
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 03-12-2008, 08:27 PM
