Thread: Can I rust proof the trail arm brackets/knuckles?
Results 1 to 19 of 19
  1. #1 Re: Can I rust proof the trail arm brackets/knuckles?
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    also, check the prices on POR-15 products. I have used this on my battery tray and other parts on my '02 GP (which I have owned since '04) and there is no rust whatsoever. I now wish that I would have dipped the entire car into this stuff back in 2004. What ever you put it on, it will never rust again
  2. #2 Re: Can I rust proof the trail arm brackets/knuckles?
    Aug 2016
    MN
    When treating rust I usually overkill. Wire wheel as best you can first. Then rust converter, then encapsulator over that, then rubberized undercoating and a top coat (rustoleum) if desired. I probably wouldn't spend the money on Eastwoods rubberized undercoating, any brand should suffice. I saw that rustoleum makes some. It's probably pretty good although I haven't tried it yet.
    POR 15 is more expensive but is supposed to be amazing. Although I have heard that it will not bond well to non rusty metal. I have personally never used it.
    The bolts are decent size and if you got them turning you are likely good to go. The trailing arm bolts themselves are another story however. I ended up grinding them off as the bolt was seized in the bushing. That's how I ended up with gmpp trailing arms as they were cheaper than stockers.
    1998 Grand Prix GTP aka The Family Sedan
    CAI, 1.8 rockers, U-bend delete, 3.4 pulley, tuned by me
    1999 Turbo Grand Prix
    L36 turbo build in progress
  1. It's out... Proof.
    By 02 WS6 TA in forum Other Vehicles
    Last Post: 05-20-2015, 09:25 AM
  2. Hello fellow Pontiyackers.New dewwwde Indian Trail, N.C.
    By Stage III in forum Introductions/Noob Questions
    Last Post: 01-07-2013, 08:11 AM
  3. bullet proof
    By nemesis in forum Visual/Body Modifications
    Last Post: 07-27-2009, 12:39 AM
  4. Water proof GenV
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 03-12-2008, 08:27 PM
