Thread: 04+ Grand Prix coolant bottle level
Results 1 to 13 of 13
  1. #1 04+ Grand Prix coolant bottle level
    Nov 2012
    Madison
    This has been eating at me.
    I used to keep it wherever towards the top.
    After replacing the o-rings on the metal elbows I decided to try and find the proper level.
    Fill it to the hot level/fill it to the cold level, I can't get the cold level line in my head because it seems too low.
    The line from the top to the bottom arrow ponts to a line. I guess thats the cold line.
    Is this all we are supposed to keep in this tank.
  2. #2 Re: 04+ Grand Prix coolant bottle level
    if the engine is cold, fill to the cold line. if hot, fill to the hot line.
  3. #3 Re: 04+ Grand Prix coolant bottle level
    Yeah, that bottom line is the cold mark. They want the level really low when cold so that as the coolant temp goes up it will push coolant into the overflow and raise the level by a few inches. They don't want a lot in there to begin with so it doesn't pour out the top.
    I got tired of never seeing the line so I just fill it up over half way because I don't care.
  4. #4 Re: 04+ Grand Prix coolant bottle level
    Nov 2012
    Madison
    Believe me this is really fvcking with me.
    As far as I can tell there is no hot line
    The manual says to fill it to the cold level but doesn't really say where just a lame picture of the engine bay with an arrow.
    If that's cold below the hose nipple level, how does it flow into the radiator when needed.
    Edit****
    Cool thanks FFDP, I'm on the same page.
    My sharpie has made marks on the bottle for my preferred amount, roughly in the middle
    I did have it blow out the overflow after filling it to the top of the line towards the cap.
  5. #5 Re: 04+ Grand Prix coolant bottle level
    The 97-03 cars do have a cold/hot line with marks, looks like the 04+ just have a cold line.
    This is a good description of the cap and tank.
    ­­The radiator cap actually increases the boiling point of your coolant by about 45 F (25 C). How does this simple cap do this? The same way a pressure cooker increases the boiling temperature of water. The cap is actually a pressure release valve, and on cars it is usually set to 15 psi. The boiling point of water increases when the water is placed under pressure.
    When the fluid in the cooling system heats up, it expands, causing the pressure to build up. The cap is the only place where this pressure can escape, so the setting of the spring on the cap determines the maximum pressure in the cooling system. When the pressure reaches 15 psi, the pressure pushes the valve open, allowing coolant to escape from the cooling system. This coolant flows through the overflow tube into the bottom of the overflow tank. This arrangement keeps air out of the system. When the radiator cools back down, a vacuum is created in the cooling system that pulls open another spring loaded valve, sucking water back in from the bottom of the overflow tank to replace the water that was expelled.
  6. #6 Re: 04+ Grand Prix coolant bottle level
    Nov 2012
    Madison
    Thanks for looking that up.
    I suppose the easy way would be to fill it up and self adjust by blowing out what it doesn't need.
  7. #7 Re: 04+ Grand Prix coolant bottle level
    no, the easy way is to fill it to the cold line, or a bit more if you like.
  8. #8 Re: 04+ Grand Prix coolant bottle level
    Nov 2012
    Madison
    Yeah I already did that once unintentionally
  9. #9 Re: 04+ Grand Prix coolant bottle level
    Antioch, IL
    I fill 50% and leave it there.
    2009 Challenger SRT8
    Expert at being gay.
  10. #10 Re: 04+ Grand Prix coolant bottle level
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Same. Halfway seems to work for me.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  11. #11 Re: 04+ Grand Prix coolant bottle level
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    I painted mine black so I don't worry about it.
    GPONA #1 Cyber Bully
  12. #12 Re: 04+ Grand Prix coolant bottle level
    Oct 2014
    portland oregon
    did ya put a spike through it to?
  13. #13 Re: 04+ Grand Prix coolant bottle level
    hangover park IL
    i leave mine out and just run the radiator 1" below full/overflowing
    ~James~ Psychotic Gearhead
