Thread: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
Results 1 to 20 of 31
  1. #1 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Aug 2016
    Lebanon, Missouri
    Okay so I went up to the dealership earlier today at about 10 AM, and got the recall done, they got the Valve cover replaced but they also took my engine cover . But nonetheless I drove it around the lot for a little bit and decided I was satisfied, that was until I got home. When I got home I noticed a metal clanking sound coming from the front left wheel, and it only does it when I turn right, It doesn't matter what speed, but only when I turn right, I tried the same thing in reverse and it doesn't do it, so it only does it when I'm going forward and turning right, kinda weird, if you guys can shed some light on this, I would gladly appreciate it!!
  2. #2 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Broken sway bar?
  3. #3 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Aug 2016
    Lebanon, Missouri
    Ill have to look in the morning, but the sway bar looked fine earlier when I was checking everything, But how could that be making the noise? it only does it when I turn right and the wheel is no where near the sway to rub on it or something. This just confuses me
  4. #4 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Suspension flex when you turn, it doesn't have to be near the tire to make noise.
    Then check for loose tire rods, bearings, springs on the struts. Control arm bushings too.
  5. #5 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Aug 2016
    Lebanon, Missouri
    Ill put her on the jack tommarow and spin the wheels and see if I can isolate it, I'll go ahead check all those too, thanks man! I'll keep you updated
  6. #6 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Aug 2016
    Lebanon, Missouri
    I replaced the CV Axle and it's still doing it, How can I check the sway bar?
  7. #7 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    St. Louis
    If you replaced the CV axle you were right there. The bars crack where the endlinks go through them and bolt to the arm. You should be able to turn the tires and look behind it to see where this is and see if it is cracked. Mine was only cracked halfway, so it was still attached to the endlink but would pop/clunk when moved.
  8. #8 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Aug 2016
    Lebanon, Missouri
    I'll check it and updated you guys when it's not raining so I can work on her again
    Sent from my SM-G920R4 using Tapatalk
  9. #9 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Aug 2016
    Lebanon, Missouri
    Okay so I just put on the new Sway bar link, and I also checked the sway bar and theirs no cracks. I'm at a loss as to whats making the noise.
  10. #10 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Aug 2016
    Lebanon, Missouri
    Okay so I think I figured the general location, its not doing it only when I turn right now, it does it just sitting there but very quietly. It might be the exhaust or something, The right CV axle needs replaced aswell. (Yippe another 100 bucks) and I also need an alignment, ugh so much to do to figure out a damn noise lmfao
  11. #11 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    HUDSON
    Check your rack and pinion mounting bolts and make sure they are tight, same goes for the engine compartment braces.
  12. #12 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Aug 2016
    Lebanon, Missouri
    I know theirs no play in the rack in pinion at all, Ill check the bolts again though, Where are the other braces located?
  13. #13 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Jan 2014
    AR
    I figure you probably don't want to get under the car much, but another thing to check is the starter. Yes, starter. Take the plastic inspection cover off (2 bolts) and try to move the starter gear in and out with your finger. It should move but spring back. If the return spring gets weak or breaks, the starter gear can kiss the flexplate because it can slide over during cornering due to inertia. Makes helluva embarrassing racket if its completely gone bad. Sound is difficult to pinpoint, is intermittent, and it echoes off curbs. Easy to check and you'll know if thats it right away. Replace starter is the fix.
  14. #14 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Aug 2016
    Lebanon, Missouri
    I don't mind being underneath it :P haha, I woulden't even have thought of checking the starter, ill check it in a bit. Ill take a video and some pictures and show you guys whats going on. See yall in a few
    Edit: It honestly is embarassing, Iv'e been rerouting to not take right turns a lot, because its so loud and embarassing xP
  15. #15 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Jan 2014
    AR
    Heres a vid of that on my 99 GT. Sound familiar? I had it jacked up on one side to make it just barely hit. Didn't seem to harm the flexplate but it could if driven long enough that way. Mine got pretty bad and the gear was just flopping back and forth.
    Its a fairly distinct sound and this vid was what helped me pinpoint the source:
    http://s807.photobucket.com/user/che...l?sort=2&o=195
  16. #16 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Aug 2016
    Lebanon, Missouri
    Yup thats pretty much what mine sounds like :P it gets worse sounding if I jack the car up
  17. #17 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Jan 2014
    AR
    Quote Originally Posted by RazerDev View Post
    You're welcome:P You'll enjoy the fast starts after the fix.
  18. #18 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Aug 2016
    Lebanon, Missouri
    I'm trying to post a video but don't know how, I took a video of it
  19. #19 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    make a youtube account or photo bucket, and link it that way.
  20. #20 Re: 01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
    Aug 2016
    Lebanon, Missouri
    https://m.youtube.com/watch?v=7oOa0DgpUKs there we go
  1. Metal scraping sound from front wheel
    By apok in forum Brakes/Suspension/Chassis
    Last Post: 04-19-2012, 09:05 PM
  2. Noise coming from steering wheel????
    By jmack98 in forum General Tech Discussion
    Last Post: 04-26-2011, 05:41 PM
  3. Loud Metal Clanking sound
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2010, 02:05 PM
  4. Clunking sound coming from driverside wheel well
    By 2000SILVERSE3800 in forum Brakes/Suspension/Chassis
    Last Post: 10-05-2010, 08:01 AM
  5. Clicking coming from front end 2004 Grand Prix
    By bjornbjorn in forum General Tech Discussion
    Last Post: 08-02-2010, 05:53 PM
