Thread: new member with anemic charging system
Results 1 to 10 of 10
Chris2017 new member with anemic... 08-25-2016, 06:29 PM
Scottydoggs Re: new member with anemic... 08-25-2016, 06:32 PM
Chris2017 Re: new member with anemic... 08-26-2016, 12:09 AM
WarStryker13 Re: new member with anemic... 08-26-2016, 12:29 AM
BillBoost37 Re: new member with anemic... 08-26-2016, 10:46 AM
Chris2017 Re: new member with anemic... 08-26-2016, 02:14 PM
Swiggles Re: new member with anemic... 08-29-2016, 02:37 PM
Chris2017 Re: new member with anemic... 08-30-2016, 02:37 PM
Swiggles new member with anemic... 08-30-2016, 03:42 PM
smg267 Re: new member with anemic... 09-01-2016, 06:51 AM
  1. #1 new member with anemic charging system
    Aug 2016
    New Jersey
    Hello group. 1998 GP GT. 300$. Needs a bunch of work, but was running well. Until I hit a big puddle hard, then drove through semi deep water. It was raining hard. Later that night the car crapped out. Later determined charging at 11.8 vdc. Replaced the alt and battery, no change. Likely possibilities? Instrument panel bulb? Don‘t think so, would have to double check. Fusible link? Assuming I determine that‘s the problem, not precisely sure how, I guess a continuity check, where do I get the material or component? Advance doesn‘t sell it. the pcm controls the alt, right? How would I check the inputs from that? Your input is much appreciated.
  2. #2 Re: new member with anemic charging system
    more on what its doing or not doing would be a great help.
    will it crank over for one? is the check engine light on or was it? it have fuel pressure and spark?
  3. #3 Re: new member with anemic charging system
    Aug 2016
    New Jersey
    The car starts, but problem is alternator is eithet defectove (tje one I replaced) or something is stopping it from dping it's job. Output is 11.8 volts aprrox. Needa to be much higher.
  4. #4 Re: new member with anemic charging system
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Belt might be slipping, if it squeals when started up, check that the belt tensioner is doing it's job... If the belt and tensioner is fine' then take the alternator back and have them test it.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  5. #5 Re: new member with anemic charging system
    11.8 doesn't sound like it's charging.
    Someone snag him a wiring diagram, one of the wires is from the pcm to apply the field in order to kick the alternator on after start up. Also you can fool the sense wire like ZZP suggests with a diode.
  6. #6 Re: new member with anemic charging system
    Aug 2016
    New Jersey
    A slipping belt would be obvious?
    I did have to replace the coolant elbow. Put a few hundred miles on the car don't think I messed up the tensioner or anything. I'll look it all over I guess.
    Yes info on checking pcm and all would be much appreciated. Autozone and All Data has resources I'm told, haven't availed myaelf of any of that yet.
  7. #7 Re: new member with anemic charging system
    Quincy, Mass
    Will the battery charge on a charger?
    No more GP 04 Impala SS Indy:
  8. #8 Re: new member with anemic charging system
    Aug 2016
    New Jersey
    Quote Originally Posted by Swiggles View Post
    It's a brand new Bosch.
    Both alternatore read 11.8 vdc when each was installed, including the reman from advance. I could just replace the serpentine belt and see what happens. Or get a tensioner from a camaro (the kind that doesn‘t have the integral lower bypass tube) ... and see what happens. Hopefully I‘ll have the time to look everything over tonight. See what I can see.
  9. #9 new member with anemic charging system
    Quincy, Mass
    Check your grounds on the trans too, if they were already corroded then puddle finished them off is bet.
    If the belts squeal other then when you go in a puddle then they need to be replaced anyways. I'm a fan of gates brand belts, they last pretty long.
  10. #10 Re: new member with anemic charging system
    SE Level Member smg267's Avatar
    Apr 2016
    killadelphia
    I'd bank on the fusible link if you replaced the alternator and battery. I had the same problem in my wife's Malibu and my brothers Ranger. I'll see if I can find a diagram on google.
    http://www.grandprixforums.net/threa...Fusible-Link(s)
  1. charging system failure
    By luckyg817 in forum General Grand Prix Discussion
    Last Post: 07-19-2014, 01:30 PM
  2. Charging System Failure
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 01-03-2013, 11:51 AM
  3. Charging System Failure Help??
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 06:19 PM
  4. Charging System Failure
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2010, 12:29 AM
  5. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
