Thread: Motor Mount - easy to do?
Results 1 to 19 of 19
  1. #1 Motor Mount - easy to do?
    canal winchester, ohio
    Guys, I know I am killing you guys with questions. Thanks in advance.
    Are the motor mounts really that easy to change for a noob like me? I did the LCA's and they were easy. I guess I need a pep talk because I am scared to jacked my car up via the oil pan and a 2x4. I am thinking of paying someone to change them (I usually dont believe in paying anyone to do anything that I can do myself). I have a clunk on the right side and the motor mount is wrecked.
    Also trying to buy a scan tool that actually reads ABS codes on a 2002 grand prix. Seems like it is the same as finding pot of gold or unicorn
  2. #2 Re: Motor Mount - easy to do?
    Kemmerer, Wyoming
    I would do it yourself, if you pay someone to do it they will do it the same way. I've done several motor mounts and transmission mounts, and white it may not be easy, it is certainly not hard
  3. #3 Re: Motor Mount - easy to do?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by michael redmon View Post
    If you did LCA's, then mounts will be easy. As long as your 2x4 spans across the pan, you will be displacing the weight, so not as big a deal as your brain is telling you. I didn't have a long enough 2x4, so used this with no issues....
    You will need a hi end scan tool, like Snap-On or OTC. None of the el-cheap-o models read brake codes.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Motor Mount - easy to do?
    I can tell this: innova 3040c doesnt work to scan ABS codes. Even though I called first. Off to Advance Auto to try and return it.
  5. #5 Re: Motor Mount - easy to do?
    autoscanner plus cp9580a does abs on a 2002 grand Prix. Guys at advance auto wouldn't delete my codes though.
  6. #6 Re: Motor Mount - easy to do?
    Quincy, Mass
    Some codes will come right back especially if it's a wire issue.
    I did the mounts yesterday, I screwed 2 2x4s together to make a 4x4 and it was easy. I did with an engine hoist last time and it was a pain, block of wood is the way to go. I do recommend jacking the back of the car up too so that the engine lines up easier with the mount when you lower it.
    No more GP 04 Impala SS Indy:
  7. #7 Re: Motor Mount - easy to do?
    Kemmerer, Wyoming
    Quote Originally Posted by Swiggles View Post
    I didn't think about jacking the back of the car up when doing the engine/transmission mounts. I only have one jack, but I do have ramps, so I might use those the next time I do the mounts. I can understand how having the car level would help everything fall back into place where it should.
  8. #8 Re: Motor Mount - easy to do?
    Quincy, Mass
    Ya, I was actually taking out the Vinnie spacers and my so called sold motor mount was leaking some fluid. I didn't jack the back up this time but I will be soon when I replace that mount again. Might make my own but I don't want pollie
  9. #9 Re: Motor Mount - easy to do?
    Kemmerer, Wyoming
    You can get a solid transmission mount from the parts store, not sure about an engine mount. I bought a solid engine mount, but it still had fluid in it. I use the 3m polyurethane window adhesive and some loctite polyurethane caulk to fill it up. It was kind of messy but not hard. If I did it again, I might consider buying two tubes of the 3m stuff because it dries faster as far as I can tell. And is black not brown like the loctite
  10. #10 Re: Motor Mount - easy to do?
    Quincy, Mass
    Well I'd like close to stock but not let the engine move, I'm sick of vibrations at idle, I'm getting to old for this crap lol
  11. #11 Re: Motor Mount - easy to do?
    Kemmerer, Wyoming
    I don't know how an engine mount would hold the engine and not let it move without transmitting some vibration. maybe a custom mount made from mild steel, but I'm no expert.
  12. #12 Re: Motor Mount - easy to do?
    Quincy, Mass
    I've had solid mounts and they don't vibrate like the solid poly mounts from zzp because I've had this too. It's just a pain in the balls finding them from parts stores that are actually solid
  13. #13 Re: Motor Mount - easy to do?
    Sep 2015
    IL
    Changing its not hard, I'd use a 2x6 or 2x8 and span it across both the trans and oil pan, makes it easier to lift the engine straight up off the studs on the mount. When you go to lower it the engine may not traverse the same path and the holes on the motor mount bracket won't line up with the studs. I just reached in and angled the mount a little to align the studs and slowly lowered the motor, didn't need to pry or heave on the engine. You won't dent your pans, just be smart and distribute the weight and jack slowly.
  14. #14 Re: Motor Mount - easy to do?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    yes the auto stores are usually wrong. if you shake the mount you can hear the fluid. Autozone tried to sell me the hydraulic one saying it was solid but he pulled the wrong part. the part numbers were the same except one has an "s" at the end.
    here are some listings for the solid mounts for reference.
    engine mount
    WESTAR EM2796S Info
    Front; Solid Mount
    Choose: [Regular Inventory] (Only 4 Remaining) ($11.61) [Private Label Package] ($12.48)
    $11.61
    ANCHOR 2796SR Info
    Front; SOLID RUBBER
    Choose: [Regular Inventory] ($14.75) [Private Label Package] (Only 1 Remaining) ($23.79)
    $14.75
    trans mount
    WESTAR EM2712S Info
    Solid Mount
    Choose: [Regular Inventory] (Only 6 Remaining) ($12.12) [Private Label Package] ($12.40)
    $12.12
  15. #15 Re: Motor Mount - easy to do?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I bought an obdII scanner from Sears for $130 and it reads ABS. it just doesn't do live data for the abs like the high end ones. the package just has to say it has the abs option.
    this one: http://www.acehardware.com/product/i...a=pla_23677926
  16. #16 Re: Motor Mount - easy to do?
    I did the motor and transmission mounts today. It was pretty easy but I sure had to jack the engine up highly high to to get the transmission mount out/in.
    To be honest, I have clunking noises in my front end so I went and just started changing parts. LCA's, Motor Mounts, next will be struts maybe. Anyways, I am surprised how well my original motor mount looked. I had a 100K bumper to bumper on this car from when I bought it in 2004. I almost wondered if it got changed at some point under warranty and I dont remember.
    Anyways, thanks guys....again. Off to research struts.
  17. #17 Re: Motor Mount - easy to do?
    Kemmerer, Wyoming
    I would suspect the sway bar or the end links
  18. #18 Re: Motor Mount - easy to do?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Quote Originally Posted by Bronco Boy View Post
    Nope. Checked if my version of Scantool did. Their FAQ says gotta spend for software. https://www.scantool.net/faqs/
  19. #19 Re: Motor Mount - easy to do?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by SaukRapids View Post
    "Can OBDLink bleed my brakes?"
    That is a sad question. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. How to change lower motor mount and trans mount
    By AlanP in forum How To Write-Ups/Tech Tips
    Last Post: 01-10-2021, 12:39 AM
  2. Easy gasless coilover mount
    By 91parkave in forum How To Write-Ups/Tech Tips
    Last Post: 05-14-2013, 02:44 PM
  3. '98 3.1L lower motor mount, tranny mount replacement help
    By Patrick551 in forum General Tech Discussion
    Last Post: 10-07-2012, 11:37 PM
  4. motor mount
    By mosley in forum Introductions/Noob Questions
    Last Post: 03-11-2011, 10:11 AM
  5. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
