I found this in my Alldata. Looks pretty easy enough.
2007 Pontiac Grand Prix V6-3.8L SC Copyright © 2008, ALLDATA 9.90 Page 1
Automatic Transmission Dipstick - Dipstick Tube: Service and Repair
Fluid Filler Tube Replacement
Removal Procedure
1. Remove the transaxle oil level indicator.
2. Raise and support the vehicle. refer to Vehicle Lifting.
3. Remove the catalytic converter from the exhaust manifold.
4. Remove the fluid filler tube bracket bolt.
5. Remove the fluid filler tube.
Installation Procedure
Important: Do NOT place the fluid filler tube seal on the fluid filler tube when installing the tube or damage to the seal will result.
1. Install the fluid filler tube seal in the transaxle.
2. Position the fluid filler tube.
Notice: Refer to Fastener Notice in Service Precautions.
3. Install the fluid filler tube bracket bolt.
Tighten the bolt to 13 N.m (115 lb in).
4. Install the catalytic converter.
5. Lower the vehicle.
Notice: Refer to Do Not Overfill the Transmission Notice in Service Precautions.
6. Check and fill the transaxle as necessary.
7. Install the transaxle oil level indicator.
8. Inspect for fluid leaks.
