Thread: ac delete kit question
Results 1 to 7 of 7
  1. #1 ac delete kit question
    Kemmerer, Wyoming
    my compressor took a dump and I didn't feel like putting a new one one, so I installed the ac delete. the kit came with spacers and bolts. I left the oem studs on the engine and just reused the nuts when I put the ac delete pulley and plate on. the instructions didn't say to remove the studs, so I just put the pulley on the studs and torqued it down with the reused nuts. was I supposed to remove the studs and use the spacers and bolts that came with the kit?
  2. #2 Re: ac delete kit question
    did the belt line up right and stay on?
    bolts wont matter studs are the same thing, but that spacer your talking about.
  3. #3 Re: ac delete kit question
    Kemmerer, Wyoming
    the belt lined up and stayed on. I took it out on the highway and flogged the car a bit just to see if it would break, and it looks ok.
  4. #4 Re: ac delete kit question
    hangover park IL
    The spacers are for a different application if I recall.
    From what I remember that AC delete kit model number that I used corresponds to several different engines not just the 3800
    ~James~ Psychotic Gearhead
  5. #5 Re: ac delete kit question
    Kemmerer, Wyoming
    when I read the instructions, it said to use the hardware kit if it was included, so I stuck the spacers in the holes on the ac delete bracket, and when I tried to put it on the studs, the spacers were too small, so I just pulled them out and stuck it on there. now I'm second guessing myself.
  6. #6 Re: ac delete kit question
    if the belts stayed on its on right.
    any kr now?
  7. #7 Re: ac delete kit question
    Kemmerer, Wyoming
    I took a scan using the aeroforce gauge, so I was only logging boost and kr, and I had 2 blips of 0.1 and at the end right before I let off, and right before it would have shifted to 3rd gear I had 2 blips of 0.4 and 0.7. I plan on taking a scan tomorrow with the tuner and giving the car some abuse to see how it holds up.
  1. U Bend delete question
    By Brenzilla01 in forum Introductions/Noob Questions
    Last Post: 05-12-2015, 02:19 PM
  2. U-bend delete and 3" catted d/p question
    By Cobras 98 Prix in forum General Tech Discussion
    Last Post: 05-12-2015, 01:26 PM
  3. resonator delete question
    By ham4864 in forum General Tech Discussion
    Last Post: 12-09-2010, 11:52 PM
  4. U Bend Delete & Resonator Delete
    By 9ordohz in forum General Tech Discussion
    Last Post: 10-23-2010, 10:57 AM
  5. U-Bend Delete Question?
    By Redbirds2230 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2010, 06:50 PM
