Thread: Starting problem, no crank, nothing
Results 1 to 10 of 10
Threaded View
  1. #7 Re: Starting problem, no crank, nothing
    Jun 2012
    St. Paul, Minnesota
    So I found that the IGN Main fuse was blown. I replaced that but I still get nothing when I turn the key.
    Where are the other fuses you mentioned? The Trans and the pcm. I didn't see them listed on either the engine bay box or the pass side one.
    I also tried replacing the ignition switch because, hey, it's under warranty and why not at this point.
    I checked the cables both at the shifter and the trans, both seem tight.
    I also read this thread:
    http://www.grandprixforums.net/threa...-stuck-in-park
    The wires are fine but when I press the brake pedal it's not actuating the release mechanism. It says that there is a brake solenoid behind the pedal, but that wouldn't inhibit it's ability to start would it? It's my next step unless someone has anything else to recommend.
    Also, I tried starting in neutral and I get the same result.
  1. 95 3.1 Ghost problem. No start. No crank.
    By Beat Club in forum General Grand Prix Discussion
    Last Post: 04-25-2014, 09:45 PM
  2. Starting Problem
    By DevilDust in forum General Tech Discussion
    Last Post: 10-18-2011, 09:46 AM
  3. Starting Problem
    By bradycat101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2010, 03:17 PM
  4. Starting Problem
    By SHayes in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2009, 02:49 PM
  5. Starting problem....
    By greatAEorion in forum General Tech Discussion
    Last Post: 09-30-2009, 09:54 AM
