under the master cylinder is the end of the cable on the tranny, theres a clip on the cable to the lever, make sure its still tight, have some one pull it out of park into gear then back in to park, you'll see the cable end having play. if theres any. you might be able to push the lever too if theres enough play to feel it.
you can also try to start it in neutral.
