01 GTP 140k on the engine and transmission.
Background: last week I was having a hard time getting the car to start, it would make an awful squelching noise and it would stutter but would eventually start. Monday comes and now it doesn’t do anything. It will not crank. It has the all the signs of a dead battery, I turn the key and I literally get nothing. All the interior lights and radio go dead while the key is in the start position and once it is released all come back on normally. Battery is good, starter is brand new. I Replaced that as I thought it was the issue because, as I said, would stutter and was making a terrible noise during starting, but once it was running everything was normal. The starter didn’t solve anything, or at least not yet. Maybe it fixed the squelch.
Some quirky things about this situation. I can’t remove the key because it will not fully go to OFF. I also cannot shift out of park, I had to use the shift lock release to get it to neutral so I could move it back a bit to work on the starter. It traveled back into park without issue, but again it will not allow me to depress the button and shift. I have also been hearing and feeling a clicking noise within the shifter whenever I am braking. It only occurs if I am in drive, if I put it into neutral and brake there is no clicking.
I read in another thread that the ignition switch could be at fault, I replaced that a few years ago so perhaps I got a faulty one? It was a Duralast part so IIRC it has a limited lifetime warranty on it.
I am looking for some input before I tear apart my steering column again.
Thanks in advance, I’m scratching my head at this point.
