Thread: Built or bought heads?
Results 1 to 9 of 9
  1. #1 Built or bought heads?
    Jun 2015
    El Paso
    I have an extra set of heads and was wondering is it worth machining them? I want to build them for performance. I currently have a 00 gtp with gen 5swapped with n*. Other then that I don't have any mods I plan to put headers with the heads. Thanks in advance!
  2. #2 Re: Built or bought heads?
    it cost me about a 100 bucks in tools to diy port and polish my heads. i lapped the valves and put em back together. if you got the time to invest doing the work its worth it. it took me a good 20 hours in all. maybe a bit more. did 2 to 4 hour working shifts on em over a few weeks time.
    exhaust, not even polished yet.
    factory casting crap that you clean up and smooth out.
  3. #3 Re: Built or bought heads?
    Kemmerer, Wyoming
    if you buy a set of heads then you can get them clearanced for an aggressive cam. you don't have to go that route. Intense sells heads that are built to pair with one of their cams and would be a good combination. but they are expensive, like 1500 just for the heads. a cheaper route would be to just do it yourself, but like Scott said, it is time consuming and hard work.
  4. #4 Re: Built or bought heads?
    Jun 2015
    El Paso
    Is there a thread where I can read up on how? Because all I got is time haha I don't mind doing it myself. But I wanted it for a streetable car still but with more flow for the gen 5
  5. #5 Re: Built or bought heads?
    sure is, i followed this one. http://www.grandprixforums.net/threa...-Porting-Guide
    and also watched countless yt vids on porting.
  6. #6 Re: Built or bought heads?
    Jun 2015
    El Paso
    Okay cool! And it will show me what tools exactly to use?
  7. #7 Re: Built or bought heads?
    the vids show you the bits, you need dual carbide cutting bits. like this, but with a longer shaft http://www.ebay.com/itm/3-U-S-A-CARB...item33b8c93e0a
    you need a few different heads to get to all the spots inside there. and a air or electric die grinder.
  8. #8 Re: Built or bought heads?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Dang Scotty. That port job looks great. You guys are temping me now
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  9. #9 Re: Built or bought heads?
    Oct 2013
    michigan
    Cool thanks for the thread. Been wanting to do a set of heads for my car for a while. Just hope to god these are not as hard as the head on my truck.
    01 gtp SD headers. gen V swap. hai. zzp 1.0 pcm. 06 Impala brakes. GMPP sway bar.
    01 ram 2500 870hp/1796lbft fmw s467.7 w/n20 old. new 66/86 compounds ????hp/????lbft.
  1. Built Heads or IC?
    By SlowM90 in forum General Tech Discussion
    Last Post: 11-16-2009, 11:05 PM
  2. I built a heads-up display (HUD).
    By drranu in forum General Tech Discussion
    Last Post: 08-19-2008, 06:30 PM
